Question about HP Computers & Internet
Files waitng to be copied to disc
When trying to save my microsoft works spreadsheet to disc it does't go there...I see it on my drive as "file ready to be written to the disc". Does this mean my RW disc is full? If not, what does this mean and why doesn't it get copied to disc automatically when I say "save"?
    President:
  • 2,559 Answers
When the window that says that opens just click on write to disk on the right side menu.This is just windows burning program and it does this to make sure that you have finished adding the files you want before it burns them to disk.
Posted on May 21, 2009
    Problem Solver:
  • 12 Answers
Hey mochajo-
Once you save them to the disc you then need to burn them. You can either click on the balloon when it comes up, or go into "my computer". Once in "my computer" right click on the cd drive. There will be an option to burn the disc.
Fred
How to move/copy user files to external hard disc (wall or usb powered) so that productivity applications default-save to the external hard disc (virtual drive) folder via...
quite a bit of "what if's there" lol
First of all, yes you CAN re-direct the 'my documents' folder to another location....be it on an internal or external drive volume. This requires careful adjustments to the HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folder
when you do this, you can assign any path to the "my documents" folder, (and also the others listed,) this will be a permanent change and will cause that path to be the new destination for files saved to 'my documents' by the OS. the actual path does not HAVE to even have the word 'documents' in it...you could call it E:\bubbles if you want.
You would continue to 'save' your new docs to 'my documents', the OS would just be interpreting a new and different destination for the Save.
Should that resource become unavailable, you would have to perform a 'save-as' and then specify a valid save location.
If you are doing this because of limited space on your C-drive, well and good, but if not, then consider Drive synchronization software instead.
These software programs allow you to specify single, or multiple folders, to copy files. you would set it up to copy from your pc to the same-named folder(s) on the external drive, and to propagate changes....so it will save files that are new or changed and delete files that were deleted, (this can be suppressed.)
One of the pitfalls of using USB devices is that drive letters are typically assigned automatically. If you do not manually assign a drive letter that is not typically accessed by the fist say....4 USB drives, it is possible for the PC to become confused and start putting files to the wrong USB device. So assign your external a high drive letter like P for portable, and don't forget to include that in the new 'path' you put in the registry.
I hope that answered your questions.
Oct 29, 2014 | Computers & Internet
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
I have several files on the computer which I would like to move to a CD....i.e. pictures, or documents. I am doing something wrong because it does not allow me to copy a file to a CD???? probably my lack...
You have to burn the files to a CD, if you have Windows XP or Vista it should do this for you, the reason you are getting the error is because unlike the hard drive, the CD is not a read / write device (ie once you copy files there they are there forever, unless you are using a re-recordable cd)
You must have a CD drive that is capable of recording data, this will be a CDRW or a DVDRW drive, most computers now have these, but if yours is only a DVDRom or a CDROM, you will not be able to copy.
To burn files to disc, Put a CD in the drive
Then get all the files you want to copy and put them in a folder (saves time)
Now click on the CD drive icon in MY computer (right click and open)
Drag the contents of the folder you created onto the cd drive which you have opened
You may get asked to format the disc, this is normal (prepare the disc)
You will then see the files you have added (says "files ready to be burned to disc")
Right mouse click on the empty space in the area where the files have been added and a menu will come up, with the command "burn to disc"
Once complete the disc will eject and you need to press finish
You can add about 700MB of files onto each CD
Jul 26, 2011 | HP Computers & Internet
Can't open my 3-2-1 Collect spreadsheet due to a missing .dll file. If I reinstall the software, will I lose the data already in the spreadsheet?
In general, you should not lose any data by reinstalling the software.
However, I always recommend backing up any files you want to save by copying it onto a USB drive. This will allow you to recover if something does go wrong.
Jul 15, 2010 | Computers & Internet
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
When i try to download certain files from my yahoo mail they never open they are usually followed by .xls
These are spreadsheet files from Microsoft Excel, a part of Microsoft Office.
If you don't have Microsoft Office installed, you can download (or obtain on a disc from a computer magazine) a free alternative called Open Office.
If you just want to view the files or print them, you can search for "Microsoft Excel Viewer", which is free.
Nov 29, 2009 | Office Equipment & Supplies
Printer "out of memory"
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Microsoft Works 8.0 Spreadsheet Problem (Vista)
The reason you are not able to open is because the files what you see in works task launcher is the history .... May be while installing sp 3 the file links migh be corrupted
search for for the documents by name or by wps for word processor document
Jun 29, 2008 | Microsoft Works 8.0 for PC
Burning Videos
Hi Cave Woman.
Can you let me know the softwrae you are useing to try to copy and also the make and model of your CDRW drive.
I will see if I can assist you.
Jan 13, 2008 | JVC Everio GZ-MG130 Camcorder
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
