Question about iRobot Roomba 440 Cordless Robot Vacuum
Roomba keeps backing up
When "clean" or "spot" bottoms depressed, Roomba will only backup (as if contacting an object) or move about 6 inches in a circle, then begin backing up again. The bumper and cliff sensors are clear of debris.
4 Suggested Answers
  • 3 Answers
SOURCE: I have the Roomba Scheduler. It just keeps going
its going in circles because it thinks it bumbing something try using commpressed air and blow out the the bumber sensors
Posted on Aug 18, 2009
pappapumpdaf
  • 635 Answers
SOURCE: my roomba won't go forward it just spins in a
You will need to take the top off to clear those wheels.
This happens a lot when cleaning new carpet. The fuzz jams the wheel switch, and dosey do you go.
Posted on Mar 11, 2010
  • 66 Answers
SOURCE: Roomba 560 beeps 9 times; we've cleaned the
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have fun
Avi
Posted on Mar 18, 2010
Why does my Roomba 620 keep stopping when it comes to an object
Does it stop or does it stop and turn to go around the object? I would clean off the sensor. I know mine gets dusty.
I say this to everyone, you must clean out any vacuum, especially the Roomba often. My Roomba gets hair and thread wrapped around every moving part. Turn it on it's back, open the two catches on the right and left. Remove the two spinning bars. get all the hair out of every place you see it, yes even wrapped into the "axles" on each end. Also the ball white/black wheel at the front has to be pried out and the hair removed from this axle. Otherwise it can't turn as easily.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
Roomba stays in same little area
First off Roomba is Ms. Roomba...a fine lady!
The problem with HER is it is a woman who can\'t make up her mind where to go. She has a Computer Brain and it is Programmed by the company to move in a direction and respond to its surroundings. If the Brain was disturbed, the commands are mixed at times and thus, incorrect signals make the unit jerk around. Contact the Service center and perhaps get a system test to locate the source of the problem.
Apr 01, 2014 | Roomba Irobot 4110 Floor-vacuuming Robot,...
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
I bought Roomba 560 robot vacuum cleaner about 3 weeks ago and it has been cleaned without problem all kind of positions of floors (also carpets) Last friday I anyway mountained nearby of outcoming door...
Roomba won't clean black carpet because it interprets it as a cliff. The sensors under the bumper tell the Roomba that it's about to fall down the stairs and it backs away. Unfortunately, because they're a safety feature, they can't be shut off.
Aug 18, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba that is 6 years old has started spinning in
Sounds like it is stuck in the "spot clean" mode. Are you familiar with this command and sure that you are not pressing it? If so, there is not much else left to do as iRobot doesn't give much repair help. All they do is offer an upgrade to a more expensive robot.
Jul 05, 2009 | Vacuums
I robot won't go forward
HAVE YOU TRIED OPENING UP THE ROOMBA AND CLEANING THE SENSORS?
Jul 06, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
I robot discovery
I have takin several Roombas apart with this problem. Basically the sensors on the bumber are blocked so the roomba thinks it is hitting something. I believe this is a design problem because it is so common. If you could see how the bumbers work, there is an infrared sending unit and an infrared receiving unit (they look like little LED's. when the bumper is pressed, a plastic piece moves between the two infrared led's blocking the transmission. This signals roomba to stop and backup. What happens over time is the sending led thing gets dislodged and moves slightly. The receiving led can't sense the signal so it thinks the bumper is depressed.
Hard to explain, but I have fixed the problem by shimming the led back in place and worst case, I drilled the hole in the plastic piece a little larger. Solved the problem and I have recaimed several roombas that were considered scrap. Irobot should fess up to this known problem and issue a fix for everyone of the defective units.
Jan 16, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Discovery
I had the same back-up, turn, move forward a couple inches, backup-up, etc. problem. Try cleaning/cutting the hair, etc. out from around the brushes, as well as around the ends of the brushes. Also, try a Q-tip to clean out the four pair of sensors (on my Roomba there are four pairs of little lenses under the bottom of the bumper) that (apparently) can cause the Roomba to think it is going over a cliff so it backs up. I didn't have a can of compressed air, so I turned it over on the grass and went after it with a leaf blower..up close. Lots of dust came out and it has worked fine since.
Sep 17, 2007 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 440 Cordless Robot Vacuum Logo
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
