Question about Tecumseh Garden
My daughter called said she hit a stick with her new lawn boy mow
Mower will run and cut grass but the self propel mechanism won't work.  Any ideas?
    President:
  • 2,559 Answers
Check and see if the belt for the drive wheels is still on the pulleys.
Posted on May 20, 2009
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
I recently purchased a Sears 22 self propelled with rear bag
they only catch grass not dirt they need air flow to work and if not porous they wouldn't work
May 31, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
129 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
