Question about Vehicle Parts & Accessories
HI I have a PIR secure pro keypad alarm, but no instructions . could someone explain how to set up and enter code. Thanks.
2 Suggested Answers
SOURCE: lossed the manual for the yale SAA5010 - PIR Siren with Keypad
Go to www2.yalelock.com/14711.epibrw
Posted on May 14, 2009
I don't remember how to set my alarm
This is the manual in .jpg/image form. Hope this helps for anyone still looking for the manual .
Mar 23, 2014 | Bell & Howell Secure Pro Keypad Alarm...
LINTECK LS400 WONT DISARM
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
  • 01282 717 490
  • email sales@lynteck.co.uk
Mar 05, 2017 | Home Security
The system randomly beeps
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
May 28, 2017 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Hi, the main box where all the wires connect to the sensor has the power on, and i've just noticed the small box where you enter the code to set the alarm does not work, yet the buttons are illuminated,...
Difficult as you didn't say what the equipment is but it sounds like there is a problem with communication between the main box and the keypad box. Have someone check that all the wires in the keypad are connected and there is no break in one of the wires. There are normally 6 connections, +ve and -ve, 2 serial connections and 2 tamper.If all the connections are ok try removing all power including the battery from the main box and reconnecting. Make sure you know all your codes including the installer code before you do this.Note if you do undo the small box the alarm may well go off!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 21, 2011 | Vacuums
I just bought the secur pro keypad alarm system and didnt bring any instructions on how to set the security code
Type the name and model number of the instrument and check on the website.good luck
Sep 02, 2010 | Lands Phones
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Resetting a Bell+Howell Secure Pro Keypad Alarm
We had ours all set up and threw out the manual. When the batteries died then it went back to the manufactures setting. We punched in 4 zeroes and pressed code. Then we put in our new 4 digit code and reset it that way. Hope it helps.
Mar 06, 2008 | Lands Phones
Vehicle Parts & Accessories Logo
535 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
