Question about Honeywell Heating & Cooling
Installed honeywell RHT2310 and fan auto works heat works no air condition
Honeywell thermostat RTH 2310 installed and fan works heat works no air condition from the gas furnance the wires all match colors and identifiers marked
3 Suggested Answers
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
heatman101
  • 43501 Answers
SOURCE: How to program Honeywell RTH
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Sep 17, 2010
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
I replaced the thermostat with a new Honewell RTH 2510B model. Before I replace the thermostat, the AC repairman added the booster to the compression since he said that was the problem why it does'nt...
Check at the furnace there is a 3 amp fuse on the circuit board you might have blown it when you installed the t-stat without shutting power off to the furnace. Also make sure RH and RC are jumpered together Y= cool G=fan W= heat R=power. let me know ok
Jul 25, 2011 | Honeywell Heating & Cooling
Honeywell RTH6350/RTH6450 Thermostats - Have two that had to be replaced as heat would not work at all. Had Honeywell tech on for 1/2 hour he could do nothing from India!! Wondering if these were...
The problem with the honeywell brand is that the only dependable units begin with TH not RTH the RTH is for residential and you can purchase those at a local home improvement store. Go on Ebay and spend the money for a quality t-stat. "you get what you pay for"
Apr 27, 2011 | Honeywell Electronic Programmable...
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
After switching from heating to cooling - air won't come on
It sounds like the fan relay in the stat itself is not closing when you make the switch over. If you have had the stat for less then 5 years it is covered. Honeywell has a full 5 year warranty on their focus pro stats, and would replace it free of charge.
Apr 02, 2009 | Honeywell Focus 6300B 5-2 Days...
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Mar 16, 2009 | Heating & Cooling
Good luck
Sep 30, 2008 | Heating & Cooling
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
213 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
