Question about Tour Trek One Click 2.0 Collapsible Push Cart
Wheel alignment the cart is veering to the right
I hav a loud roaring noise from front end of my peugeot 307 only at road speed a steady roar that gets louder
Wheel bearing brother, does the noise go away when you veer to the left or right? Quiet veering right?( it's the TT wheel bearing), quiet veering left, ( left bearing is culprit
Dec 18, 2014 | Cars & Trucks
Steering veers to left-tires look ok
yes, something has happened to cause this to happen, take it to an alignment shop and they will inspect it and let you know what is needed
Jan 29, 2014 | 2006 Scion xB
2000 ford windstar steering wheel shakes horribly and I let go of wheel veers to the right
These are two seperate problems. The veering to the left is your alignment. This is cheap, about 80 bucks at sears. The shaking is usually ur transmission or tcs
May 03, 2013 | Cars & Trucks
Steering problems with Mercedes ML 63 Amg
you need to get it repaired by a professional alignment shop before you kill someone or yourself
Oct 28, 2017 | Cars & Trucks
Car vibrates at slow speed, veering to the right,steering wheel vibrates; vibration less at higher speeds; within last two weeks couple of times steering hard, revved up in neutral it comes back to easy...
check tyres for wear-wheel balance needed if visibly ok-have a wheel alignment after a tyre rotation-best even tyres to be put on fronts-they will carry out a safety check all suspension and steering before doing the wheel alignment
Jul 13, 2009 | Chrysler Town & Country Cars & Trucks
Sterring veers hard to right
have you tryed to rotate the two front tires side to side to see if the pull goes to the other side ?
Mar 29, 2009 | 2001 Dodge Ram 2500 Truck
Poor control...swaying
It could be your wheel alignment which usually causes the veering like you described. Have it checked for Alignment - not expensive and also good for even wear of the tires.
Hope this helps, please don't forget to rate my solution,
Thanks.
Mar 15, 2009 | 2003 Toyota Highlander
1997 diesel suburban steering goes left
I doubt it's your 4x4. Most transfer case will start turning the front driveshaft, meaning that BOTH front wheels would try to turn.
Could be a brake pad/caliper locking up on your left wheel. That'll make that wheel turn slower resulting in the veering left.
Could also be a wheel bearing. However usually you'll hear a grinding noise to go along with that. And it'll pull rather consistently in that direction rather than suddenly.
Or, what first comes to mind is that your steering box is loose, or the gear inside the steering box is stripped in one spot. Or your front tie rods could be shifting or possibly ball joints. These would cause a sudden shifting/veering.
All of these things are front end related. And also very dangerous. Take it down to any alignment shop, have them put it on a lift, and diagnose immediately.
Worse case scenerio is that a front end part breaks and sends you out of control and into someone else. Please get it checked. A diesel Suburban could do a lot of damage.
Feb 10, 2009 | 1999 GMC Suburban
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Front wheel veering right (hard right)
You can take it to a bike shop.  They can re-align the wheel for you.
May 30, 2007 | Bell Sports Scout Jogger
Tour Trek One Click 2.0 Collapsible Push Cart Logo
100 people viewed this question
Top Tour Trek Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Tour Trek Golf Expert? Answer questions, earn points and help others
