Question about Black & Decker CTO4500S Toaster Oven
Top heating element stopped working. - Black & Decker CTO4500S Toaster Oven
Top heating bars stopped working
Dear Tang_Tuong,
I would check all of the fuses, the internal fuses and wiring for any signs of damage and that particularly from heat. Also multimeter the connectors of the wiring to the element and see if you are getting a voltage reading, if you get a reading from the wiring and the element is not heating up, then you need to replace that element, do these checks for all of the internal components and you will find the one at fault.
I do hope this is the fixya for you and look forward to hearing how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Euro-Pro Toaster Ovens
Top element not working all wires are connected
Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
Mar 08, 2010 | Black & Decker TRO651 Toast-R-Oven Toaster...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & Decker CTO4500S Toaster Oven Logo
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
