Question about Kenmore Oasis HE 27082 Top Load Washer
Codes my washer when started keeps making a beeping sound and will not work it flashes dl and I have to keep stopping and restarting it to get it to work, why
jsrock516
  • 5911 Answers
SOURCE: KENMORE ELITE WASHER error (DL) then (F)
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
Posted on May 07, 2008
SOURCE: Washer won't start; has alternating "dl" and "f" errors....can't reset
I try to restart, but my machine did not lock the door, then can not run as normal, what shoud i do to make them run again
Posted on Sep 29, 2007
ronaldsuboc
  • 449 Answers
SOURCE: F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Posted on Sep 19, 2008
larryyb
  • 291 Answers
SOURCE: kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: dL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Posted on Jul 27, 2009
hi!!!!
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Feb 14, 2009 | Kenmore Elite 45986 Front Load Washer
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Elite washer keeps stopping and beeping. It flashes either DL or F or H. I push pause and reset but it does it intermittently. It tries to drain after these messages if I don't hit pause.
Okay, it sounds like you may have a couple of things going on with your washer. The first link I'm providing explains the "FH" error and what you have to do to diagnose it:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This "Fdl" error is generally caused by a failed door latch assembly. This second link explains how to replace the door lacth if defective:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
I would recommend you check the simple things first. Check to make sure you don't have a siphoning problem and make sure the drain pump isn't clogged. Then, I would recommend replacing the door lacth if the "Fdl" error keeps occuring. Some of these problems can generate multiple error codes. It could be that the door latch isn't working properly and is causing the washer to stop intermittently. Coupled with the possibility that you could have something clogging your drain pump. If you require additonal assistance, please post back and let me know. I hope this helps you.
Aug 01, 2008 | Whirlpool Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
1,159 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
