Finis Neptune MP3 Player Logo
A
Anonymous Posted on Jan 01, 2014
NEPTUNE FINIS FROZEN - Finis Neptune MP3 Player
My windows will not accept my device. What driver do I need? Neptune Finis
Windows does not require a driver to use this device. If connected via a USB port, it should be recognized by Windows as a removable disc drive and will show up under the "My Computer" menu, or "This PC" menu, depending upon Windows version. There is no other GUI or assistant type software utilized.
My computer is not recognizing that the device although it did in the past
Try reinstalling the driver for your device or recovering the operating system to a time when the device was recognised
My neptune stop playing randomly
I had the same problem after logging less than 1000 yrds.
I dont have THE solution. Nor does Fnis.They offered a discount on the new model. Im looking for a firmware flash. if I find ill let you know
I dont see it my removable disk drive
ensure that the message "USB Connected" is displayed in the unit. If when you conenct o the computer it only charges the battery, clean or peel off the contacts. THat happened to me in two units, and it worked.
The connection usb plug of the SwiMP3 is damaged and I can't charge the unit!! I have the unit for 7 months now.
Refael,
Thank you for letting us know of this problem you are experiencing. I work in FINIS Technical Support and would be happy to assist you further. If you could go to our support site (finisinc.com/support) I can further process your case!
Thanks FINIS Technical Support
Top Finis Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
