Question about Vacuums
Whistle noise AirSpeed Zuum AS5203A
I purchased a eureka airspeed unlimited rEwing and it is soo loud..is it supposed to be?
That depends, is it just loud or is it loud from a vibrating noise? Does the machine shake? If not, then the machine is just loud unfortunately.
Feb 26, 2016 | Eureka Vacuums
Changed belt on my eureka airspeed sweeper n since makes loud noise, really loud n vibrates
Sonja, Recheck belt installation, see if it is riding in proper groove or is twisted.
Press the helpful button and follow me on fixya for more tips and info.
Feb 11, 2016 | Eureka Vacuums
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
Loss of suction
do not connect to electricity at this point claim a little work area put a blanket down as you are going to strip it all down into little bits clean and then put it all back,
Take apart power cable unwrap, unclip middle glass cylinder section to empty rubbish out, there should be a filter at the base that you can see now unclip clean put back, empty rubbish out of cylinder clean base and top rubber section and filter section with fine brush, use a wet cloth to wipe clean all black rubber suction connectors put back, at the back there will be a hose connector at the base unplug clean put back and make sure no debris is in any of the connectors and underneath where the floor brush is before you start puting it all back , Hope this helps
Feb 17, 2014 | Eureka AirSpeed Bagless Zuum
Jusy shut off while using
Your sweeper may have overheated. I don't know what brand you have but I hope you weren't trying to vacuum pine needles from the Christmas tree. Pine needles are sticky and will clog up any vacuum sweeper. Check your sweeper to make sure the tubes (hose & pipes that carry dirt) are clean and clear. I used to service Oreck vacuum sweepers.
Dec 30, 2013 | Eureka AirSpeed Bagless Zuum
Just shut off
Might be overheated due to clogged filters
Vacuum over heats and shuts off
check to see if the brush is turning under it if belt is broke or slipping it will do that
Dec 16, 2013 | Eureka AS5203A Airspeed Zuum Black Upright...
Whistle noise from filter
Try moving the filter a little while it is running. This is a common problem caused by the air bypassing the filter. The more clogged the filter is the more it will whistle but sometimes it will whistle with a new filter. Sometimes you may get it stopped for a while but then it will start up again or come and go.
Sep 01, 2013 | Dyson DC25 Vacuum
Dyson model 26 makes whistling noise
sucked up something, turn off, take apart, get ''something'' out, put together again, try, will work
Apr 20, 2013 | Dyson Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
