Question about Frigidaire Freezers
Unable to find defrost timer for Frigidaire UFPD-15L
Unable to find defrost timer that will work with Frigidaire freezer UFPD-15L
  • Anonymous Mar 13, 2014
    where is the defrost timer located in frigidaire FGHB2844LF
  • 1,906 Answers
Gem corp. makes this part
Posted on May 20, 2009
When my Frigidaire upright automatic defrost freezer stopped running. I turned dial on defrost timer and it started up again cooling fine but havent noticed if compressor has shut off yet for a break...
Hello friend, thank you for your post!
From what you have described you are having a problem with your Frigidaire freezer not shutting off and you feel it may be due to a defrost timer. This issue you are seeing could be a problem with your timer or thermostat. You might want to perform a reset on your freezer and you can do that by disconnecting the power cord from it for roughly ten minutes. If that does not help resolve your issue you might want to have a professional technician out to perform a diagnosis and repair. I hope this is helpful. -Matt
Mar 09, 2015 | Frigidaire Freezers
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle. If you have to do it again, you should have the timer checked, or just replace it.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Nov 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire Freezer Model FFU20F9FW1 defrost problems
you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
Mar 05, 2008 | Freezers
Freezers Logo
180 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
