Question about JVC DR-MV1S DVD Recorder/VCR
Unit turns off when hot
Unit performs perfectly on record or play modes, but turns off automatically after 2 to 3 days of stand-by mode, or 3 hours of play or record operation. It can be manually turned on again, and functions perfectly, after 2 to 3 hous of being off. It has always run HOT since purchase.
  • 6,784 Answers
Hi, this is a defective power board fan in this device. the power board fan should be replaced in order to prevent the down time due to over heating. i will post a link to the replacement fan below.
CLICK HERE TO PURCHASE YOUR NEW REPLACEMENT FAN
Posted on May 20, 2009
Panasonic 1080p DVD Recorder flashes "Hello" cannot turn off, eject DVD, play or anything
I just had this problem the other day. Unplug the unit for 2 minutes. When you plug it back in and get a the 000 press the power button for about 5 seconds and that will put it back in stand by mode. Hit the DVD open button instead of the power button. Hope this helps
Aug 03, 2015 | Panasonic Televison & Video
My plug has been changed how do I get ep off of my unit
Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
Jun 22, 2015 | Televison & Video
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
Hi. My Philips CD Recorder CDR 785 stops and turn off when i try to recorder from spotify.
The Unit turns itself off automatically after a few (variable) time when simply reading a CD and also when burning, then after 1 or 2 seconds it turns on and goes automatically in stand by mode. Any solution? Thanks.
Mar 08, 2011 | Philips CDR785 3-Disc CD Recorder
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
JVC DR-MV1S DVD Recorder/VCR Logo
180 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
