SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
SOURCE: water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
SOURCE: TURN OFF ALARM
Assuming you have allready checked the operators manual, check again on page 19 for "Accoustic Signal". To deactivate the signal select a program press two of the option buttons and hold until a short signal is emitted. There you have it.
SOURCE: Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
