Question about Samsung ES28 Digital Camera
Wont work with rechargeable batteries!
Works with non-rechargeable batteries but not with rechargeable ones! A green light comes on with the rechargeable ones when you press the power button but as soon as you release it the light goes off? Help!
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
SOURCE: Camera won't turn on
Are you sure you are using the correct battery specified in the manual of the camera?
Posted on Aug 18, 2009
dlundmark
  • 797 Answers
SOURCE: Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Posted on Oct 20, 2009
SOURCE: Camera S-860 Samsung- Powers Up,Lense opens &
i had this problem, and i read the thingy about the batteries and it didnt work but than i tried out of my own desperation. turning the camera on and as the lens pops slightly out banging it from behind on to the table which kind of pushed the lens out. i did this a few times and the camera seems to be working fine now :D
Posted on Nov 22, 2009
  • 11967 Answers
SOURCE: camera turns on briefly then off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 20, 2010
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Flashing red/green battery light
Some non-Dell batteries will cause the led to flash. There are some aftermarket batteries that have circuitry which 'fools the laptop' and prevents the flashing. As long as the battery is working there's nothing to worry about.
Feb 23, 2010 | Dell Inspiron E1705 Notebook
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Camera wont turn on batteries are new
I had the same problem that the green light turned on then the red one, even though the camera batteries where new.
I found a solution for this problem, hope it works for all as it did for me.
http://www.sendspace.com/file/ysolwv
The link shows the images of the steps you need to follow to fix this problem.
This problem actually is from low batteries or low voltage in the camera, but its not because the batteries are dead, it is because the batteries don't have a good contact with the metal conductors in the camera.
In the images you can see that the camera has a plastic cover for the battery contacts, so the way to fix it is to remove that plastic cover with a small screwdriver, and pop in the new batteries.
With that it should fix the problem. Hope it works.
Jan 02, 2009 | Kodak EasyShare C533 Digital Camera
Power on Problem
please make sure the batteries you are using are genuine.
Jul 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Power wont stay on
Remove batteru for a minute and insert it again. There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2 (icon looks like a wrench with number 2 on it)
- Scroll down to Battery Type
Under Battery Type, there are two options:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Nov 13, 2007 | Samsung Digimax S630 Digital Camera
Canon a85 problem
Could be that the non-rechargeable batteries are blocking current from the rechargeable ones. Either get all rechargeable and charge them AT LEAST 14 hours before using, or use all alkaline - fresh. If the same display happens it could be a defective CCD which is being replaced FREE by Canon. Go here for details: http://www.imaging-resource.com/badccds.html
Nov 25, 2006 | Canon PowerShot A85 Digital Camera
Samsung ES28 Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
