Question about Breville Kitchen Appliances - Others
Breville steamer not working
Steamer
IrishDruid
  • 2712 Answers
SOURCE: Tefal Vitacuisine steamer manual
You can download the user manual HERE.
You will need Adobe Acrobat Reader to view this file. If your computer is not equiped with Acrobat Reader, please download it HERE.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 29, 2008
  • 3 Answers
SOURCE: Salton (Richard Simmons) EST7 steamer
http://www.salton.com.au/files/prod_manual_file_114.pdf
Posted on Jan 16, 2009
SOURCE: instructions for durabrand food steamer please
I am looking for an instructions manual for a Durabrand double steamer/cooker, Model #FS2007
Posted on Apr 12, 2009
  • 94 Answers
SOURCE: instructions for a cookworks steamer
http://www.manualsonline.com/
Posted on Jan 22, 2010
SOURCE: Shark steamer doesn't work
Taking it apart isn't all that difficult if you are vaguely handy, have the time and the patience to dig into what it took China's best engineers years to design. And it beat either sending your $150 lump to a landfill or $$$ending it back for repair$$$. Here' what I did:
We had the same problem with ours...worked for about 6 months and quit. We were using tap water. DON'T. Use distilled only.
Tried the white vinegar trick. Nope. Tried the CLR trick. Nope. Decided to disassemble, even it was junk I might learn something.
Tools: two phillips (hex) head screwdrivers, one medium, one small (not tiny). They need to have fairly narrow shanks to fit into the deep holes on the body. Needle-nose pliers. Pair of scissors.
UNPLUG IT!!! And let it cool for at least an hour before you start and take the handle apart at the pump so it's less awkward. The boiler inside stays very hot for quite a long time, even when its unplugged.
1. Take out the multiple screws that hold the purple body together. Careful...these are cheap screws (surprised?) and the heads may strip or the plastic threads may strip. You may just ending up forcing some of the screws out. Do the screws slowly and do everything in your power to keep the screwdriver head square with the screws.
2. You can't take the two halves completely apart; the wiring is in the way. That's the biggest hassle of the whole project. That and the mop head that you can't take off. Inside you'll see a metal "boiler" about the size of a can of tomato paste. It has wiring (thin) and tubing (fat) running into it. If it's still hot, let it cool.
3. There are also four screws inside that hold the water reservoir in place. If you take those you can get easier access to the boiler, though the reservoir will still be attached to the body of the unit.
NOTE: The boiler is held in place by two brackets and four very small screws and little fiber insulation washers. DO NOT take the screws all the way out (like I did) as they are extreeeeeemly difficult to get back in place. Just loosen them about 3/4s of the way so you can move the brackets and lift out the boiler. The boiler will still be attached to its wiring. Don't disturb the wires; you just have to carefully work around them.
4. With a pair of needle-nose pliers, squeeze the little spring clamp that holds the tube that runs from the water reservoir into the boiler and slide it up the tube a bit and _carefully_ slide the tube off the nipple on the boiler. Mine cracked at the end when I did this so I needed to trim the end square again with scissors. A sharp box knife would work too, but use the scissors to trim the webbed insulation fabric if needed.
4. On the other end of the boiler is a tube that goes to the mop head. Undo the clip there, too, and slide it back and again slide off the tube.
5. Look at the nipple for the tube that goes to the mop head. It is probably clogged with calcium deposits that the vinegar or CLR didn't touch. It will look solid. It is. That's probably your problem.
6. I took a power drill and a very small drill bit (1/16") and drilled out the calcium - it's very soft - to free up the hole. Then took the next size bit (3/32" or so) and widened the hole further, sort of like getting a root canal (ouch!). Don't drill too deeply into the boiler as you may hit something important. When it's open, left over water, vinegar or CLR will come out. You should now be able to blow through the boiler from the newly cleaned nipple, with air coming out the other hole (to the reservoir). The reservoir line must be disconnected to do this because there's a little one way valve in the reservoir line that keeps the from steam going back into the tank and not out the mop head (your drip coffee maker works the same way, as I also discovered when ours clogged...same problem: Calcium build up).
7. Return the two tubes to the boiler (don't forget to push the spring clips back in place) and reattach the boiler to the body. Aren't you glad you didn't take off the boiler brackets?
8. Before you do the final assembly, put in some DISTILLED water (rainwater works, too if its clean. It's naturally "distilled.") and plug it in. It probably won't steam until you pump it a couple of times but I bet it's working again. Be careful with the steam, though. If it works, do the final reassembly. If it doesn't, well you tried. But I bet dollars to doughnuts that it is working again.
Hope this solves your problem! Happy mopping.
CBear in New Mexico
Posted on Feb 16, 2010
I got breville but the steamer is not working what can I do
It is probably clogged with hard water deposits. You can use white vinager or something like CLR pour into the iron an let it set for awhile an allow it to eat away the deposits. Don't turn on iron until it's finished an cleaned with fresh water.
Jul 23, 2017 | Breville Kitchen Appliances - Others
Breville express exc15
I would search on ebay for someone who has got one.
Jul 14, 2014 | Sunbeam SUN-4710 5-Cup Rice Cooker
I need to find an instruction manual for a Breville vtp068 steamer, can you help?
Couldn't find the exact model, yet emailing this address could help. AskUs@BrevilleUSA.com good luck.
Dec 28, 2010 | Breville Health Smart Steamer
Breville RC3 Rice Cooker and Steamer Leaves starchy mess on work top when cooking rice, am I doing some thing wrong?
Thats normal when cooking rice!
If you dont want these starchy mess, try to cook less rice so that boiling water won't come off from the cover!
Nov 06, 2010 | Breville Kitchen Appliances - Others
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
Aug 31, 2008 | Breville ESP8XL Espresso Machine
No coffee
Does it come out water from the steamer?
if that is the case I would clean the filter on the machine.
Jul 16, 2008 | Breville ESP8XL Espresso Machine
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Kitchen Appliances - Others Logo
55 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
