Question about Acer TravelMate 2300 Notebook
Acer Travelmate 2400series
My notebook wont power on with or without the battery and or ac outlet
  • 93 Answers
It need a physical check up,there is connection that cut the electric  current can't direct the other part or power supply on your notebook
Posted on Oct 26, 2007
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
My Acer Travelmate 737tlv has a dead battery. Can I use it with the power adapter anyway?
If the battery is dead, you will need to replace the battery if you plan on going portable. Yes you can use your laptop with the power adapter without the battery installed or on. You need to treat this as it was a home computer with a power cord, and becareful not unplugging it until system has fully shut down to avoid surge, short circuit.
Jan 30, 2011 | Acer TravelMate 737TLV Notebook
Power will not turn on
Power drain pc first. Remove battery and unplug Ac adapter. Then press and hold power button for 15-20 sec. Then put back in battery and ac adapter. Try if it will turn on. If not, try one at a time, battery and ac adapter to turn pc on. If it turns on with battery only, possible ac adapter issue. Try a different outlet to plug it in. If still no go, try a different ac adapter. If it doesnt work still, possibly it is a motherboard issue.
May 25, 2010 | Acer TravelMate 2480-2968 Notebook
Acer travelmate 4100 works fine with no battery
Try to use another OS, like Ubuntu Live, and see if the mouse and KB will freeze. If they wont freeze, It is better to reinstall the OS.
If they will freeze again with Ubuntu, then I am sorry to tell you that the battery life has finished.
The only thing to do is to replace it for another one new.
Thanks for rating!!
Apr 21, 2010 | Acer TravelMate 4100 Notebook
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
Acer travelmate does not battery charge but pwr jack, battery ok
First power drain your system take the battery out unplug the acadapter and then push the power button on the laptop and keep it pressed for 2 mins without connecting any power souce this will drain the static power from the syteme after few mins connect the battery first and then connect the ac adapter that should take care of the issue.
May 05, 2009 | Acer TravelMate 2300 Notebook
Battery status LED blinkings amber
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Jan 25, 2009 | Acer TravelMate 3260-4874 Notebook
When on AC will not charge or operate as AC powered.
You Need To Replace The DC Jack..< the port where your AC Adapter plugs into the laptop>
Nov 19, 2008 | Acer TravelMate 2201LCi Notebook
Computers & Internet Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
