Question about Moultrie Game Spy M-990i
Trail shows detecting on screen will not take pictures
What features should one look for while purchasing a trail camera?
he features should one look for while purchasing a trail camera -
1. Picture Quality
Picture quality doesn't just involve the number of megapixels that a camera has, this metric also takes into consideration the clarity of the picture, the color composition and how it contrasts the subject with the foreground and the background.
Resolution is measured by megapixels and the notion that the higher the megapixels count the better the quality is a false notion that marketers use to make customers think otherwise. The resolution works together with the other features to give the best image the camera can capture.
Checking trail camera picture quality involves looking at the picture online and comparing them. Outdoor shops also have units available for testing that customers can take sample pictures with to judge the quality of the picture.
2. Night Mode
Probably the most important feature in a trail camera, the ability to record and capture images at night is what gives trail cameras the edge when it comes to tracking. The perfect trail camera should have either infrared or black LED flash. The bulb-type camera flash can scare wildlife away when it takes pictures at night. Game especially nocturnal ones are sensitive to sudden bursts of light and, as a result, they will scatter and probably never go back to where the trail camera is.
It is understandable that night pictures would have significantly less quality in the images it captures but the photos should still be crisp and clear within the acceptable range. Some cameras can eliminate red-eye from the subject but this is an optional feature.
3. Video quality
Videos are a newly added feature to trail cameras and most of them would have the option to select the length of the video. Others would also include the option to go HD or VGA with their recordings. Check the quality of the video in both day and night modes, the video playback should be clear and blur-free.
4.Time Lapse
Time lapse videos are taken even when the sensors are not triggered and the output would be a video of the landscape but at a higher speed setting. For example, the camera would record for 8 hours but the resulting time lapse video would only be about 10 seconds. This is an optional feature for hunters are they are more focuses on the hunt rather than playing with video effects.
5. Power Consumption
Almost all trail cameras run on 8 AA batteries but not all of them would have the same consumption rating. Some would have a power saving feature while some would have many features that would use up the juice on the batteries at a faster rate. Ideally, fresh batteries should be able to take about 16,000 pictures before draining out.
6. Memory
Most trail cameras would have built-in memory already, however small, but the unit itself should be able to support at least a 32GB SD Card. The external SD card has the advantage over the internal memory especially when downloading the captured images. SD Cards can simply be removed from the device and plugged into a computer whereas an internal memory camera would require removing it from the mount, and storage unit, and then plugging it in which translates to time and effort lost
7. Detection Circuit
The Detection Circuit is what detects game passing in from of the camera and is also the same mechanism that takes the picture or video and records it. Here are its components:
Trigger Time - once a wild animal enters into the detection zone, the amount of time used to snap the picture is called Trigger Time.
Recovery Time - after a camera triggers the lens and memory would need some time to store the recently captured picture and prepare for the next one, this is called Recovery time.
Sensors - these are what detects game in front of the camera and gives the signal to the mechanism to take the picture. Trail cameras often use infrared sensors.
Detection Zone - this is the maximum range that the sensors can detect movement. This also correlates to the effective distance of the camera lens.
Simply put, the detection circuit is the trail camera and the faster the trigger and recovery time the better. A wider detection zone would also be ideal for a trail camera.
8. Advanced Features
Higher end models have some advanced features that can include:
Remote Access - this provides hunters the ability to check on the images captured at the comfort of their homes, camps or offices.
Viewfinder - this is slowly becoming a standard among trail cameras. This allows the hunter to view images and videos without connecting the unit to a computer. This also acts as the menu screen for the unit.
9. Price
Each year the price of parts go down as components get smaller and easier to manufacture and this also brings down the standard price of new trail cameras. Nowadays, it is not unheard of to have a good quality camera to be priced at less than $200.
10. Brand Recognition
There are many brands to choose from with the same features but read about customer feedback and see which brand brings in more customer loyalty than others. This is indicative of a good quality product.
Mar 29, 2017 | Cameras
My Acer E5 522G is detecting my TV, but there is no picture on the screen. The HDMI cable is fine as I can use it on my V5 I have here. How do I get it fixed?
The tv that your acer is detecting but showing no picture might have an unsupported screen resolution. Your acer might be able to handle a tv with *1280 x 1460 resolution but not one with a *1800 x 2200 screen resolution (* just random numbers for an example) hope this helps
Apr 16, 2016 | Acer Televison & Video
Dont know how to use 2" screen to view pictures on d-900 i
Go to menu where it shows camera setup hit the up arrow key should show playback. If still need help call Moultire 8006533334 option 1 and 1 for a live person
Oct 31, 2013 | Moultrie D-900I 10 MP Black IR Mini-Camera
No memory message on screen after set up and no pictures after being in field
Are you checking pic on the camera? If you using a micro sd switch it to sandisk sdhc then test camera again.
Oct 27, 2013 | Moultrie Game Spy D555i Trail Camera
Want to know the relationship between the rear trailing arm and the control arm. If you had the rear trailing arm fixed because of recall then 2 months later they say the control arm came loose and broke...
The recall for your vehicle may or may not have included replacement of the trailing arm. The recall says that the trailing arm is to be "inspected" then it will be replaced, or modified at the discresion of the person performing the inspection. If it was "replaced", it would require the control arms to be disconnected and reconnected. If it was only "modified" there would have been no disassembly of the control arms required. See the picture below. The picture shows the rear suspension parts. Notice that the upper control arm and the lower control arm bolt to the trailing arm. (which is what also houses the hub and bearing with the wheel speed sensor.) I hope this helps you to resolve your issue.
Mar 08, 2011 | 2003 Hyundai Santa Fe
I just bought a Tasco Digital Trail Camera - 119223C . During the setup my camera display also shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does...
I just bought,last August, a Tasco Digital Trail Camera - 119223C . Took pictures until Jaunary 2011, my camera display shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does anyone know what 'Loc' means? I tried to reformat card, I also so not get a Y/N option for formatting. I bought a new card and changed batteries. no change!
Nov 14, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Sharp Aquos 37 inch LCD HDTV - black trails on picture when hot
LCD LAG COMPENSATION CIRCUIT? never heard of that, dosent mean it dosent exist, you may have a LCD driver board issue, never seen the trails thing on Aquos, have had to update the software on many of these critters though.
Jul 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Moultrie Game Spy M-990i Logo
47 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
