SOURCE: I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
SOURCE: We have a Rowenta iron
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
SOURCE: My Rowenta Effective DX1700 is less than a year
There is a known issue with this happening for this model. The resolution is that you replace the switch.
