Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Loose white wire on lr5500 - Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Have a oreck u4180 upright, while cleaning out blockage a white wire came loose and now won't start .where does it attach?
Jackie,
The white wire more than likely came from the motor. Look to see if there is another white wire that might still be connected to the motor and if there is, there should be another terminal to connect your loose wire. That should take care of it. Hope this helps.
Aug 29, 2015 | Oreck Vacuums
Hunter "French quarter " ceiling fan stops without being required to. Lights operate on or off without being required to.
loose wire connection White wire is neutral black wire fan blue wire lights. Since the light and fan are both affected that indicates the white wire is loose at the power panel or at the top area of the fan assembly.
Jun 15, 2015 | Hunter 52" Ceiling Fan With Light And...
House wiring
TAKE EXTREME CAUTION WHEN WORKING ON LIVE WIRES!
THIS WORK SHOULD BE PERFORMED BY TRAINED ELECTRICIAN.
REMOVE BREAKER FROM BACK OF PANEL & INSPECT FOR LOOSE AND WORN CONNECTIONS THAT CAUSE BURNS AND MELTED METAL CONNECTORS.
Jan 27, 2015 | Electrical Supplies
We have a DX 1900. It fell and wires came loose and the back jarred off. There are two loose blue wires and one white one. Do all 3 go together? If just the blues go together, where does the white
YOU Must contact to Rowenta, for get help via chat or phone. Normally the electrical diagram is not comming with any iron.
However the iron electric coming with 2 wires red +black. and attached to the 2 wires from the iron
God bless you
Sep 23, 2012 | Rowenta DG5030 Iron
So, with that being said, if we assume the white wire in the box is actually acting as a second black wire, when I went to hook up the first dimmer switch, I connected the black wire in the box to one of...
The most likely candidate is the white wire. In a standard residential installation, the white wire is often the neutral connection - and wiring the dimmer hot to neutral will cause exactly what you described.
However, often times the white wire is instead a traveller wire being run to the switch from the fixture (which, it sounds like that's what you were assuming) - in which case, the other likely candidate would be having a loose power connection coming in contact with ground. Sometimes this can be a loose screw or, as you describe, a loose wire.
Your best choice would be to install a standard 50-cent light switch first. If you connect it together and it works - then you know a connection came loose and made a bad contact - so then you can try using another dimmer. If you connect it and the breaker trips - then you know you're using the wrong wires/connections.
Aug 26, 2010 | Lightolier Ivory Galaxy Slide Dimmer...
Replaced a light switch for a ceiling fan. Switch
On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
All white wires normally go together.
Jun 05, 2010 | Hampton Bay 52 In.Carriage House II in...
I have a white wire - approx. 5' with no home that I can see
please connect it to earth(chassis) and look if it is stil sparking. i think it is the wire to stop the gen. it used to be fit behind the handle to start and stop please let me know, thanks.
Feb 05, 2010 | Briggs & Stratton Power Products 5,550...
New fixture, flourescent light controlled by switch. There are two bundles of three wires into connectors, one is black,one is white. Two single wires, one white,one red. Light has a black,white,and...
There should be two wires at the bottom of the fan that are loose ends ,, these wires connect to the two loose wires from the lighting kit, white to white and color to color .
Nov 18, 2009 | PROGRESS Lighting Ceiling Fan
Neutral (white) wire connection
Use caution when dealing with AC, it can be deadly.
The black wire by accepted standards is the 'hot' wire and will measure (when active) 110-125 volts (in the US) to ground or the white neutral wire in a normal household system.
The white wire may have a couple of volts when measured to an earth ground or any green (or green-yellow) wire which is (by standards) connected to earth ground, often via plumbing pipes in some homes, or a visible or buried grounding rod driven several feet into the earth.
The black (hot) wire is the one customarily 'switched.'
I would highly recommend you have a qualified electrician reconnect the strayed wires to protect yourself and the fan.
Jul 05, 2008 | Dryers
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
