Question about Refrigerators
Replace Light in Defy F640 Double Door Fridge Freezer
dididsaythat
  • 291 Answers
SOURCE: fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Posted on Oct 25, 2007
  • 1314 Answers
SOURCE: Fridge door does not
you can tilt it back a little rule of thumb that i use is to tilt them back open the door as normal let it go and see if it shuts its self if that doesnt work let me know we will try something else
Posted on Feb 10, 2008
SOURCE: how to set the thermostat? gaggenau fridge freezer
how to set thermostat on double door fridge freezer
Posted on Dec 09, 2008
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
SOURCE: i have defy fridge/freezer combo c380, freezer
how long have you had this problem? I have a problem with my C440 and defy is offering me a C380 at a very reduced price. I was wondering about the relyability?
Posted on May 26, 2010
Red alarm light on Defy F640 keeps on flickering and the fridge is not cooling as it used too.
possible defrost issue. May be caused by non-sealing doors, broken defrost heaters, bad thermistor, bad control board.
Dec 01, 2016 | Refrigerators
How do i replace the bulb on my Defy double door fridge F640?
In my opinion, it is very risky job. It may damage your fridge itself if you are not properly aware of that. I prefer a refrigerator mechanic to do this job.
Aug 04, 2016 | Cell Phones
DEFY F640 Fridge/Freezer side by side. The freezer made clicking sound, and green light flicker for a while then stops. Now it is not freezing anymore.
Hallo
It could be the theromstat, clicksen or the compressor.
But I think its the clicksen it is faulty and can't handle the amp stress test I hope for your sake other wise I believe its the compressor.
Regards
May 26, 2016 | Refrigerators
Defy f640 wiring diagram
Defy F640 freezer fan keeps switching on and off and does not cool.
Jan 19, 2014 | Freezers
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
