Question about Home
Vitra clara inlet valve
Vitra cistern parts
it could just be bad water pressure how are your cold taps in the same room?
have you used bloo loo type things in your cistern? there may be a blockage in your inlet or a build up of lyme.
check this
Jun 17, 2013 | Home
I have A VITRA CORNER TOILET DEUL FLUSH BUTTEN BROKEN AND ITS VERY SLOW TO FILL
Your water valve must be clogged with sediment in the line. It has nearly shut the water off.
Feb 19, 2013 | VitrA Home
Float is adjusted to the proper height but water continues to slowly rise until it reaches the overflow
Hi lucy edwards...
Change the inlet valve (ballcock) it is leaking and non-repairable
Once you replace your ballcock with a new one and set the water level that will solve your problem.
Please take time to rate me
Aug 30, 2011 | VitrA Aria Toilet with Round Bowl /...
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Location of low side port to install freon on 2000 grand vitra AC unit 6 cylinder
mcdevito75 here, The low side port of your A/C is located on one of the shiny metal lines comeing out of the firewall, they are attached to the evaporator under the dash, from the firewall carefully follow these silver lines till you reach the charge port. The port may be covered with a brass looking cap, un srew the capp and the port looks like the valve on the tire.
Jun 18, 2010 | 1999 Suzuki Grand Vitara
Replacement part for VitrA cistern
I trust you mean the "Flapper Valve". They are available and most hardware stores.
Get a Universal type as they fit most units. Take the old one with you. If you turn the water off at the wall it will stop it from running while you're away
Nov 26, 2009 | VitrA Aria Toilet with Elongated Bowl/...
VitrA #5055 toilet why will it not stop running
the flapper is not closing all the way in the tank. if, when the handle is at rest, the flapper chain is too taut, the flapper is not closing all the way. so loosen the chain. if there is slack, the flapper is not making a good seal and is letting water through. or if in the tank the water is going over the standing up overflow tube, you need to adjust the float. if you have the ball float, lift it up slowly and see if the water stops running. if not, replace the ballcock (valve where the float is attached. if it does stop, unscrew the ball a little or bend the ball arm down a bit until the water stops short of the overflow. if you have the shuttle float, do the same test. if the water does shut off, adjust the shuttle accordingly.
Nov 12, 2009 | VitrA Aria Toilet with Round Bowl /...
Do you have a contact number for the manufacturer for the ILO television
I hope this does it for ya!
iLO Corp
2200 MONROE ST.
SANTA CLARA, CA 95050
United States
Phone: +1 (866) 456-3837
Administrative Contact:
iLO Corp (PDKQK) email.pgif?md5=e75d73587e88808b39b9b98256a8def5&face=atomic_clock_radio&size=7&color=000000&bgcolor=ffffff&format[]=transparent&face=trebuchet&size=9&color=0000ff&bgcolor=ffffff&format[]=underline&format[]=transparent
iLO Corp
2200 MONROE ST.
United States
Technical Contact:
iLO Corp (LP8NJ) email.pgif?md5=e75d73587e88808b39b9b98256a8def5&face=atomic_clock_radio&size=7&color=000000&bgcolor=ffffff&format[]=transparent&face=trebuchet&size=9&color=0000ff&bgcolor=ffffff&format[]=underline&format[]=transparent
iLO Corp
2200 MONROE ST.
United States
Phone: +1 (866) 456-3738
Billing Contact:
iLO Corp (ZA8L6) email.pgif?md5=e75d73587e88808b39b9b98256a8def5&face=atomic_clock_radio&size=7&color=000000&bgcolor=ffffff&format[]=transparent&face=trebuchet&size=9&color=0000ff&bgcolor=ffffff&format[]=underline&format[]=transparent
iLO Corp
2200 MONROE ST.
United States
Please rate my response and help keep this area of fix it FREE!
Thank You!
Jan 22, 2009 | iLO 2600 Television
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
