Question about Weather King 10AJA6001AH Air Conditioner
Hardly blows cold air
Our air conditioner is hardly blowing any cold air out and the pipe was iced over so I shut it off. There is a resert button on the back of the unit...what should I do?
    Problem Solver:
  • 8 Answers
Use a heat gun to melt the iced pipes before using it again. have your aircon's thermostat checked/replaced. the thermostat's supposed to stop the compressor at a certain temp. which is before it freezes the pipes
Posted on May 20, 2009
Goldman capf3636b6. Fan outside is running blowing cold air to the outside.Inside is making a humming sound but not running.If I turn it off all of it stopsThere is some ice visible on the pipes
System needs to be thawed out, so turn it off before something else breaks, cause pipes are probably plugged and stopping any movement inside the system, Try using a blow dryer on high heat to help with the thaw out of the pipes with the ice build-up , then leave it off for a couple of hours and then try to turn it on again see if the unit in the house is running or blowing cold air again. Turn it on HIGH...!!!!
Aug 09, 2015 | Heating & Cooling
House a/c compressor runs for a while then shuts off
It could be going out on a high head pressure safety
Jul 04, 2014 | Ruud /rheem R22 /2 Ton/13 Seer Ac...
Home A/C is not blowing Cool air ice on hose
Not blowing at all or not blowing cold? Big difference.
Aug 31, 2013 | Goodman Heating & Cooling
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
High efficiency outside air conditioner does not cool house, seems to for a while but stops. The pipes at the air conditioner are coated with ice so seems to produce cold but does not blow that through the...
Unfortunately, the ice coating isn't normal, in fact, it is an indication that your unit is low on freon or a blockage. But could also mean a few other things.
But about the only thing you can do yourself is make sure that the fan is turning or not.
Jul 07, 2011 | Frigidaire Heating & Cooling
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
My air conditioner blows cold air for a time and then it turns warm. After a long period of time (the afternoon) the breaker will auto shut off. What can cause this?
there are several things,, one check the outside unit when you have warm air to see if the pipes are icing up,, if so it can be dirty unit,,or low in gas,,or high pressure switch,,hope this help you
Sep 02, 2009 | Heating & Cooling
Cant make it blow out hot air.
You do not mention the model. Most aircon remotes have a mode button which has three or four icons. On cooling there will be a ice crystal icon on the lcd display. Pressing the mode button (sometimes behind a cover on the remote) this icon will change. You want to set it to the "sun" shaped icon
Jun 02, 2009 | LG Heating & Cooling
Weather King 10AJA6001AH Air Conditioner Logo
160 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
