Question about KitchenAid KEYS700LQ Electric Dryer
Everything seems normal except it doesnt start
Dryer wont start..timer clicks and stops when door is opened..light burns inside...help!!!
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on May 20, 2009
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
After i put the clothes in the dryer and close the door, the dryer will not start when i press start. It makes a short "click" sound and then doesnt start. The timer seems to be fine and the light inside...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2010 | Kenmore 92822 / 92824 / 92826 Gas Dryer
My Kenmore Series 90 gas dryer which has worked very well for 10-11 years began starting up by itself. It seems when we run it normally that it stops and works well, BUT if we leave it alone with the door...
Id look more at it being a bad start button that might be sticking some kenmores have the seprate switch away from the timer if yours does not have this then replace the timer
Apr 28, 2010 | Dryers
Just stopped working still has power-inside light comes on and timer makes noise when you turn dial but does not start when you push start button
This sounds like the door switch. But it could also be the non-resettable thermal fuse inside. Open the door, depress the door switch until it clicks, and while holding it in see if the dryer starts.
Jan 05, 2010 | Whirlpool Dryers
Cooking doesnt start
Microwave?
Generic advice follows.
Do you open the door while the machine is cooking? Do it a lot? For a long time (months)? Check your door safety interlock switches. The microswitches can not stand that type of abuse. I have personal knowledge on this. I try not to open the door until it stops, but it is hard usually to do that!!!
If you need more help, let me know.
a
Sep 21, 2009 | Frigidaire FMV156DC Microwave Oven
I have a maytag dryer that has power, but the light doesnt work(but it is not burned out) and the dryer will not start. timer works, can anyone tell me what could be the problem
You probably have a bad door switch. When the door is open, the switch should turn on the light. When the door is closed, the switch should allow the dryer to start.
Jun 15, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
KitchenAid KEYS700LQ Electric Dryer Logo
132 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
