Question about Seagate Barracuda Green St1500dl004 1. Terabyte 1. Tb Sata300 5400rpm
S2hejxod9oooo5 what case do I buy to make this an external hard drive
3 Suggested Answers
  • 4 Answers
SOURCE: How to open case: Seagate ST3160203U2RK External Hard Drive ??
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
FixinFax
  • 3085 Answers
SOURCE: Seagate Barracuda external hardrive - damage to usb connector on
Yes you can, to all of the above. It's just a standard har d drive in the case
Posted on May 27, 2010
External hard drive was dropped and now no power
You may have accidently broken some of the internal components of the external enclosure. If you have the know how, you should take the hard drive out and test it in a computer to see if the hard drive is still good. If the hard drive is still good, you can get away with buying another enclosure. If the hard drive isnt good, your better off just buying another external drive.
Mar 05, 2011 | Seagate USB 2.0 External Enclosure + 400GB...
I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
Hope this helps!
Regards,
Joe
Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
When i connect my wd 1tb hard drive i get usb device not recognised plz help
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Western Digital My Book Essential 1TB...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Internal hard drive
They do make cases that you can buy to turn an internal HD into an external. Best Buy I think sells them.
Dec 19, 2009 | Seagate 160GB 3.5" External USB Drive 160...
My computer will not recognize my external hard drive
the external hard drive's motherboard is burnt take it apart (this will be a little hard but it will come apart) after you take apart u will see it is just an internal hard drive in a case so either...
1) put it inside your computer as an internal or..
2) buy a new external hard drive case (that will have a new hdd motherboard in it)
after you install it either way your computer will reconize the hd and WORK i done this just yesterday.
Nov 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
What kind of case enclosure (3.5) should I buy?
Check out the review on the hard drive case we use in our shop at www.ccl-la.com We have been using these drive cases for a while and have had no complaints, and it works for both IDE and SATA.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 09, 2009 | Western Digital USB 2.0 External Enclosure...
Wd200eb
Buy an external hard drive case. Remove the hard drive from its current case and put in the new one. Another option is to buy the identical external hard drive again, use the power supply to get everything off of it. Then you can return it if you don't need it anymore...
Jun 12, 2008 | Western Digital Protege WD200EB 20 GB Hard...
Seagate Barracuda Green St1500dl004 1. Terabyte 1. Tb Sata300 5400rpm Logo
628 people viewed this question
Top Seagate Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Seagate Measuring Tool and Sensor Expert? Answer questions, earn points and help others
