Question about Canon CanoScan 8400F Flatbed Scanner
Canon 8400f suddenly will not allow neg scan option
My Canon 8400f suddenly does not give me the option to scan negatives or slides.  The only option both in simple and advanced modes is platen.  It has worked fine for nearly two years before this.  I've already tried uninstalling and reinstalling the driver.  Any ideas?
Just had the same problem, check the connection going into the top part of the scanner at the back and restart which ever program your using... got mine sorted
Posted on May 22, 2009
Can I scan a negative 4X5 black\white to make a photo
In general, yes, you can scan a negative and make a photo from it. I don't really know your model scanner, my Canon 8400f has a film adapter and a light in the cover, but would have to scan a 4x5 in sections and I would have to piece it together after scanning.
The results I get from scanning negs are very good, as good as I ever got in my darkroom.
Oct 31, 2014 | Canon CanoScan 8800F Flatbed Scanner
I have a Canon 8400F film printer/scanner
'Tain't necessary. And not getting the part can be an improvement.
I cut out a cardboard template that allows me to scan 10 slides rather than the 4 of Canon's official slide adapter.
All the Canon part does is position them precisely so cropping and rotation are automatic. With Photoshop skills (File ' Automate), you can do the same yourself for whatever size. I ended up doing Brownie, 35, and 126 (gasp!) also.
For extra credit, make your adapter(s) out of genuine plastic rather than whatever cereal box you have lying around.
Jul 06, 2012 | Canon CanoScan 8400F Film Scanner
Unable to set CanoScan 8400F for color slides. The protective sheet has been removed from the document cover, and the slide film guide installed. Photo Studio Acquire panel Source selection has only...
kindly let me know your operating system so that i can give you precise solution. By the way you should go with the review for which I am providing a link below. If this does not solves ur problem kindly let me know alongwith ur operating system.
http://www.pcreview.co.uk/forums/canoscan-8400f-settings-35mm-negatives-4-x6-photos-t2637157.html
Jul 01, 2011 | Canon Office Equipment & Supplies
The light on the lid, for scanning negatives won't move
You will most likely find that the FAU cable that connects the lift up lid part to the lower part of the scanner has at least one fractured wire within it. There are eight quite fine wires and the constant opening and closing of the lid has caused this to occur. Unless you have some micro-surgery skills and a small soldering iron it's off to the scanner shop, I'm afraid.
Mar 17, 2009 | Canon CanoScan 8400F Film Scanner
Cant scan slides
Make sure the lead from the lid is plugged in properly to back of scanner. I had the same problem and this fixed mine.
Nov 14, 2008 | Canon CanoScan 8400F Flatbed Scanner
How do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Jul 07, 2008 | Canon CanoScan 8400F Flatbed Scanner
Selection menu doesn't give "color positive slide"
Check the cable connection to the lid of the scanner. If this is loose, then you will only get the "Platen" option in the drop down menu.
Nov 23, 2007 | Canon CanoScan 8400F Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
597 people viewed this question
old marine
old marine
