Yamaha rx v665
Only goes to 25% volume
  • 336 Answers
SOURCE: how do i connect my cable tv to my yamaha rx-v665?
If your tv has an audio out jack attach a rca cable from that to your receiver any audio input.
Posted on Dec 20, 2009
Bennytechkid
  • 99 Answers
SOURCE: Yamaha RX-V800 volume control
i would say that the component that controls the sound level (called a potentionmeter) or (varible resistor) is either broken or faulty....you will need to remove the cover and inspect the area around the volume control just to make sure it is not broken or that any wiring has just become dry jointed....if all is good then what i would suggest to do is to find out the value of the pot...normally there around 10-50K then youll need to get a replacement...if this still dosen't fix it or your confident enough to look or fix it yourself i would take it to a local electronics repair shop....remeber to disconnect unit from power before removing cover hope this helps,ben
Posted on Jan 09, 2010
ETRONIC
  • 62 Answers
SOURCE: how do i connect my xbox 360 to my yamaha rx-v665
If you are gonna connect the x-box to the yamaha directly you would have to connect the red and white cables to one of the inputs on the reciever and the yellow to the video on your tv.
Posted on Feb 16, 2010
  • 14 Answers
SOURCE: I have a Yamaha RX - V665 and the Right rear
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: Is there a code so I can connect my Pioneer PD
What do you mean - code? It's hardware, connect it via its optical digital cable.
Posted on May 29, 2010
Testimonial: "This is very helpful. Thank you."
The sound cut off all of a sudden and I now can't get any mode to work
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired no problem.
May 11, 2016 | Yamaha RX-V665 Receiver
My New Xfinity XR 5 remote codes will not turn my receiver on & off . OOnly control Volume & Mute.
You either have the wrong remote code or it may be a case where-as the remote will not properly operate "all" functions. Wrong programming "codes" with universal remote controls often operate some but not ALL functions and some remotes are unable to duplicate every function. If all else fails, you use two remotes with one for Xfinity and one that came with your stereo.
Mar 28, 2015 | Yamaha RX-V665 Receiver
How to code yamaha rx-v665 into directv remote
Go to the Directv Remote programming Page and enter your device
It will give you the correct codes or a universal code for your brand receiver.
Oct 02, 2014 | Yamaha RX-V663 Receiver
RX-V665 turns on for a second then turns off
don`t open it yet
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 13, 2012 | Yamaha RX-V665 Receiver
I need a manual
Hello.
I found the manual you are looking for! Here is the link:
http://static.highspeedbackbone.net/pdf/RX-V665_manual.pdf
Please rate. =)
Aug 03, 2011 | Yamaha RX-V665 Receiver
Need a manual
Simple web searches get answers faster than waiting for one of us to pick up the question.
Try "Yamaha RX-V665 manual"
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Is there a code so I can connect my Pioneer PD F505 to my Yamaha RX V665?
May 29, 2010 | Yamaha RX-V663 Receiver
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
How do i connect my cable tv to my yamaha rx-v665? i do not have a cable box
Dec 19, 2009 | Yamaha RX-V663 Receiver
19 people viewed this question
 Grubhead
Grubhead
