Question about Maytag Washing Machines
Machine changes cycles very loudly-just a noisy machine
When its agitating it sounds like its chewing nails-then when it goes from one cycle to another it bangs REALLY LOUD
    Champion:
  • 219 Answers
U need transmisson replaced very expensive better to get new machine
Posted on May 21, 2009
Noisy when agitating. has not been moved
Noise comes when some part of the moving part is getting collided or getting stuck somewhere. Try cleaning the wash cycle and the rinse drum. It is the only cause of noise. Thank you, Sir to visit Fixya.
Sep 17, 2009 | Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
