Question about Boston Acoustics Audio Players & Recorders
Install boston microcenter 8 ohm speaker - Boston Acoustics Audio Players & Recorders
5 Suggested Answers
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
djnick989
  • 1067 Answers
SOURCE: 4 ohm speakers for 8 ohm impedence on receiver (HT)
ya cant run them 4 ohm on 8 ohm sterio run super hot then fail sooner gota get sum nice 8 ohm ones ok flouece off ebay is relly good cheap 8 ohm
Posted on Jan 24, 2008
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
SOURCE: HOmetech HT503 8 ohm speakers
WITHOUT ANY PROBLEM. THE SOUND WILL BE LITTLE SOFT BUT YOU CANNOT MAKE ANY PROBLE USING 8 OHM ON 3 OHMS AMPLIFIER
Posted on Aug 07, 2009
4-8 ohm output
it is load resistance. set the amplifier switch to the resistance ( X amount ohms) to match your speakers. Although running 4 ohm speakers at the 8 ohm setting is louder, it will hurt your amp
most home/semi pro speakers are 8 ohm, while car speakers are 4 ohm. If you are doing a multi speaker pa/intercom install use your formula to calculate total load is 2 8 ohm speakers in parallel are four ohms . express them as fractions and add the denominator ie:8/1 +8/1 = 8/2 or 4/1 or 4. now connect that in series (add the top numbers)with another 2 speakers in parallel and you get back to 8 ohm load. repeat the same process over and over and you can hook up to 32 speakers to the amp without needing the 70 volt tap. hope this helped.
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
I have a Makita BMR100 radio. Stock speakers are 3.25" 8 ohm with an 8 watt 8 ohm amplifier. I replaced speakers with better 4" 4 ohm but they're not really compatible with an 8 ohm amp. I...
Buy an 8 ohm speaker and wire it in series-parallel look up images of of combination series-parallel wiring this allows wiring all speakers and keeping the 8 ohm loaf on the amplifier. Should get more linear volume between speakers. Not sure if replacement is worth it, those speakers are pretty good and work well with rain and jobsite conditions. I am planning to install some 8 ohm half inch tweeters on my Makita radio and using the series parallel wiring. Plead note series-parallel wiring is not series wiring or parallel wiring. It is s totally different way of wiring it that uses both names.
Jun 02, 2011 | Makita BMR100 Radio
I am installing a MDS-6a system in my home Must I use all 8 ohm speaker thru up the house ? Can I use 6 ohm ,can I mix ? Thanks
That depends on the amp. If the amp is rated at 6 Ohm's you can, but it's best to stick to the same ohm speakers. If it is rated at 8 Ohm NEVER connect 6 Ohm speakers. The golden rule you can go higher but NEVER lower than the amps rated output. So if it says 6 to 8 ohms on the amp you can use the the 6 ohms speakers.
May 04, 2011 | Channel Plus MDS-6A Amplifier
Can I install 4 6 ohms speakers on an 8 ohms a/v receiver? receiver Sony STD HD 800 speaker system: Jamo S413 HC S5 Home theatre system,
Best Answer - Chosen by Voters An ohm is a unit of electrical resistance. You can think of it as your speaker will impede or pull 8 ohms from the amplifier that is powering it.
8 ohms is less resistance than 4ohms. So a 4 ohm speaker would require more juice than your 8 ohm.
If this is the only speaker, then that's all the resistance you have to worry about handling. If you had two of these speakers wired in parallel, then the total impedence would be up to be 4 ohms, because each speaker actually reduces the resistance in the circuit...so 8 ohms + 8 ohms = 4 ohms.
You use this information to make sure your amplifier is powerful enough for the speakers. If the speakers have too much resistance, they'll fry your amp.
Here's a good sentence to help explain, but I recommend reading the article I linked in sources...
"An amplifier designed to put out 100 watts into 8 ohms will put out 200 watts into 4 ohms. Two 8 ohms speakers wired in parallel (4 ohms total) would cause the amplifer to produce 200 watts." Source(s): http://www.marktaw.com/recording/Electro…
Nov 26, 2009 | Sony STR-DH800
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
What kind of cables for Boston Speakers?
You want stranded wire, speaker wire, 14 - 12 gauge
Oct 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Replacing sub speaker
May 18, 2009 | Sony SA-WM500 Subwoofer
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Getting Boston Acoustic ba735 to work with my Dell
Hi Tom,
I just got the dell vostro 410 and had the same problem... So I unpluged the digital cable, got a 1/8 male to 1/8 male cord, plugged it into the analog in on the back of ba735 and the other end into my headphone jack on the front of my system and the speakers work great again......... I have XP Prof. installed as os. Hope this helps... by the way 1/8 is the plug that is on the opposite end of your ba735 digital cable that plugs into your computer, just need a cable with that plug on both ends...
Good Luck!
G
Nov 08, 2008 | Boston Acoustics BA735 Computer Speakers
18 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
