Question about LG AKB72975301 Remote Control
Reset remote LG universal remote for tv does not work. How do you reset or reprogram it for a sony tv?
SOURCE: Remote Sensor
I heard that LG TVs have a problem with the TV not responding to the remote control (there is nothing wrong with the remote control). Hopefully your TV is still under the 2 year warranty. Go to LGService.com and report the problem. They told me that it's a common problem. They need to order the part and let me know when it comes in. (my TV is a LG 50PC1DRA)
The Akai TV might have LG guts inside.
Posted on Jan 06, 2009
techman007
  • 1112 Answers
SOURCE: Remote sensor on TV (LG 42PM1MA) seems to be broken.
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Posted on Sep 29, 2009
Testimonial: "Thanks a lot. Seems you've done this yourself :)"
rulds2008
  • 3866 Answers
SOURCE: Remote code for LG 50pq2000?
Here is a list of manufacture remote codes I hope this helps.
http://www.hifi-remote.com/ofa/codes-tv.shtml
if it does not you need to call lg directly.
Thanks and please do be coniderate to rate your free support today.
Posted on Apr 28, 2010
Testimonial: "This list of codes didn't help me (already tried that code), but thanks for a quick answer!"
SOURCE: LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
Posted on Sep 01, 2010
arnalipants
  • 36 Answers
SOURCE: I must be near my
you have a prblem on your t.v maybe sensor is not work
Posted on Sep 07, 2010
CHUNGHOP RM 139ex FOR LG TV
The best universal remote is the Logitech Harmony remote. It never gets outdated and will work on any tv. You use their website to program the tv and any other component you have hooked up to it. For example: If you get a new bluray player to replace your old dvd player you simply log back on the website, connect the usb cable that comes with the remote and reprogram the remote.
Mar 20, 2014 | none CHUNGHOP RM-139EX Universal Remote...
Remote On/Off not working - Sensor Broken
Hey, maybe you should try reprogramming your universal and see if that works. Might want to try testing all the codes that work for LG and see if they'd work. If that doesn't work, find a site like <a href="http://www.remotecontrolhookup.com/lg/">www.remotecontrolhookup.com/lg/</a> and see if you can find your original and buy it and try it out. If that still doesn't work, send it back and you may need to find a local tv repair shop to look at your tv rf sensor.
Jun 05, 2012 | LG 42PC3D 42 in. Plasma Television
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
I have a big button universal remote control that I need to reprogram and can not.
Most of the universal remotes need a code specifically for the type of TV, VCR, DVD device you have... Some of the codes for Sony TV are...0128 or 0013 or 0002 or 0071 or 0380 or 0152; Give them a try.
Feb 02, 2011 | Sony Televison & Video
We have a proscan 1080P -- our little girl got ahold of the remote and now I think it is not programmed. It isn't doing anything on our tv. I can change the picture -- like zoom, wide, normal but it won't...
This is an orignial remote to the tv?Not a universal remote wright?Yes,it can't be reprograms,only universal remote can be reprogramed,by re entering the tv codes.Take the battery out like 24 hrs put it back in the remote should reset itself.Should work now,not then the remote CPU is dead.Sorry the remote is junk now.Try webste like Remotes.com to buy an exact to the original remote.
Oct 19, 2010 | Proscan Televison & Video
How to open child lock on cineplus LG TV manually as remote is not working
really very difficult situation..
because you can't operate your tv by both remote and front panel buttons..
however there should be a solution
solution:by a new branded universal remote or LG remote for your model..
eg:
RCA universal remote,
sony RM-VL600
philips PH301s etc
it is the only solution available to solve your problem
regards,
cseian
Jun 14, 2010 | Televison & Video
I sat on my remote and now it doesnt work is there a way to reprogram the remote?
Check if the remote is still transmitting. You can do this with a digital camera. Point the Remote at the camera's lens then start pressing buttons on the remote. If you see a blinking light from where the remote transmits on the digital camera's LCD screen, the remote is functioning properly.
If you do not see it transmitting, replace the batteries. If it still does not work, the only thing you can really do is get a new remote, there is no way to reprogram the LG remote. You can get a universal for for pretty cheap or you can contact LG to get the exact replacement remote for your TV to ensure it has all the functions needed.
Oct 09, 2009 | LG 42LG30 42 in. LCD HDTV
Remote code for Hyundai Q320 TV
como funciona un control remoto universal para un tv hyundai
Feb 29, 2008 | Sony RM-V310 Remote Control
Remote code for Sony Homethetre on LG Remote
LG 32 LX2R TV REMOTE CODE TO WORK A SONY VTX-D8 U
Dec 30, 2007 | Televison & Video
LG AKB72975301 Remote Control Logo
77 people viewed this question
Computer Repairing
Computer Repairing
