Question about Tacsew Sewing Machines
Where do you find parts for a tacsew t111
On/on switches with wiring and the on/off switch
  • 1116 Answers
SOURCE: where can i download a tacsew t111 155 manual
I could not find a download, but found this company has a manual - http://www.allbrands.com/products/abp07642-1204.html
Posted on Feb 24, 2010
  • 1116 Answers
SOURCE: I can't seem to get my tension right. It keeps
Check the needle to be sure it is the correct size for the type of fabric you are sewing and does not have a burr on the tip.
Raise the presser foot when threading the machine and this will open the tension control so the thread can properly seat into the control and form a proper stitch.
When the machine is threaded with the presser foot down, the tension control closes and the thread cannot enter as it should. In this case, the bobbin thread is the only thread with tension.
Posted on Mar 24, 2010
robert97527
  • 5 Answers
SOURCE: I just purchased a Tacsew
Hi Diane...you can wind bobbins while you are sewing your product, or you can wind them seperately. To wind them seperately, pull out the bobbin case, lift the presser feet up and lock them in the up position, undo the threading beyond the tension assembly. The takeup will create a birdsnest if you don;t pull the thread from it. Wind your bobbins, the re-thread your machine, insert your bobbin case, drop the presser feet, pick up the bobbin thread and sew away. If you need any other input, call me at 888-283-9640.
Robert with National Sewing Supply
Posted on Jan 26, 2011
wiringlunati
  • 576 Answers
SOURCE: tacsew t111-155 sewing machine skipping stitches
I don't have firsthand knowledge of this machine, but the machines I've used would do this when the thread tension was too high. Check the thread path for any dirt or buildup of fuzz from the thread. Also, check to make sure the thread tension adjustment isn't set too tight. Gently tugging on each thread one at a time may reveal which thread is binding and make your search more efficient. I hope this helps.
Posted on Feb 14, 2011
  • 186 Answers
SOURCE: My tacsew T111-115 keeps coming unthreaded. I have checked the threading and believe it is correct. What else could be wrong?
tension on thread two tight or cotton is cheap
Posted on Aug 03, 2012
Can the presser foot be adjusted to acomadate thicker fabric?
You may try contacting this vendor:
Tacsew Industrial Sewing Machines at SewingGold com including the T111 155...
Unfortunately, trying to sew thicker fabric than intended for the machine could cause damage. Most machines have a fabric "thickness" limit.
Nov 07, 2016 | Tacsew Sewing Machines
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
Tacsew t111 155
the needle bar may need a adjustment at a sewing machine repair shop.
Mar 18, 2014 | Sewing Machines
Tacsew t111 155
the machine needs to be checked to see why the needle is froze, could possibly be a broken part.
Tacsew t111 155
here is a link to try
Contact Us
Tacsew t111-155 sewing machine skipping stitches after rethreading and changing needle
Feb 14, 2011 | Tacsew 20U43 Sewing Machine
I just purchased a Tacsew T111-155 sewing machine with a bobbin rewinder. Since the bobbin rewinder runs off the drive belt, how do you rewind the bobbin without the needle moving? Is there a button or a...
Jan 01, 2011 | Sewing Machines
I have problems with my tension settings
upper tension needs to be tighter
Jan 16, 2008 | Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Tacsew Sewing Machines Experts
Shehu Pro
Shehu Pro
Nick Olsen
ray gallant
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
