Question about Philips Magnavox DVD/VCR Dual Player
Tape wont eject - Philips Magnavox DVD/VCR Dual Player
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
Tape wont eject
From the tape library console, on the menu, select the slot view option, find out the slot of the tape you want to eject. Then move the tape in that slot to the male slot using the 'media move' option menu. The tape will be now ejected to the male slot.
Please come back and post your ratings if this solution helps you in anyway. Thnx
Mar 16, 2010 | HP StorageWorks DAT 72 Tape Drive
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
The power wont stay on and its flashing a 3
the tape eject mechanism is either in the wrong place,or there is a tape stuck inside.take off the cover,and make sure that the two cage piecers,top and bottom are ejected all the way.
Jul 04, 2009 | Philips Televison & Video
Tapes stuck in the cassette and dooes wont eject on both sides
I hate to say this but you may have wrapped the spook around the player inside. I have not had much luck opening jammed doors that result from spooled up tapes.
Richard
May 31, 2009 | Sony Audio Players & Recorders
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Problem with my hp Dat 160 usb backup tape drive
make sure your backup server is not preventing the media being removed
try rebooting your server, if the tape then can be ejected it is probably your backup software.
If the tape wont eject even after both server and drive have been rebooted it is probably faulty and needs to go for warranty exchange with HP
Jul 30, 2008 | HP (C1530B) DAT Tape Drive
Philips Magnavox DVD/VCR Dual Player Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
