Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Poulan Riding Mower won't crank, battery OK.
My Poulan HD145H42G 14.5 hp B&S 42 " won't fire. Battery seems ok. Not even a click when I turn switch. Seems like an open circuit on seat, blade or drive safety switch. Seat switch checks out ok. Still looking for the other 2 switches. Are they accessible without tearing the mower apart?
Could it be the solenoid? How do I check?
  • tablesawtom Jun 06, 2009
    I apparently had a bad/dirty connection because when I got in there to do the testing tried to get the solenoid out and retightened and it started right up. Worked 2 weeks and now it won't start again. But, this time it gives me some rapid clicks but the starter won't turn the flywheel. If I rotate the pully shaft by hand and then try to start, the starter energizes, engages the flywheel but only turns it a few degrees then starts clicking.
    If I turn the pully by hand and try the starter again it does the same thing. Voltmeter on the solenoid/starter wire to ground shows only about 1 Volt when the key is turned.
  • 376 Answers
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
  • Dwain Pippen Jun 06, 2009
    Now, that rapid clicking is usually a sign of a low battery or corroded terminals on the battery. From what you're saying, you're turning the engine past the compression stroke, then the starter will turn the engine till it hits the compression stroke again. Make sure your battery is up. Wiggling wires does sometimes fix problems.lol. It's happened to me more than once. Sometimes I'm not sure what I did, but things will start working again. It's usually corrosion on terminals and moving them sometimes regains connection, particularly on the ignition switch. You still could have a faulty solenoid. You should show the same volts on the live wire at the bottom of the solenoid (when unplugged) and ign. switch is turned to start, as you have on the battery.
Where is carburetor on poulan 17.5 hp 42 inch cut riding mower
Under air filter. First check battery voltage. Should be 12-12 1/2 V
Mar 15, 2016 | Poulan Garden
The coil of my poulan riding mower isn't firing. How do I check to see if its good or not
remove the top cover from the engine then remove the small wire that goes to the coil crank it over if you have spark the you have a bad safety switch is still have no spark then the coil is bad
Jun 27, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My poulan pro riding mower clicks but wont turn over?
Check the battery voltage with a multimeter. It is possibly low. If so, you can try to charge it. At your own risk, you can attempt to "jump" the mower battery with a car battery. I don't advise this as a common practice. They both are 12 volts, the difference is in the amount of CCA available (Cold Cranking Amps).
Jan 11, 2011 | Poulan Garden
Poulan Pro PP165H42A. Was running OK. Started coughing and died. Got it to start and got back to the garage with it poping and sputtering. Assumed low on gas. Some gas remained (1 1/2 inch)while I...
Sounds like the starter solenoid which is basically on the side of the tractor below the key inside the side panel. Part number 146154 and you can get it from Searspartsdirect.com or Jackssmallengine.com . Easy fix just pull the negative battery cable off the battery first so you don't get sparks flying! Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. ...
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Jul 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Sears riding mower
Even new batteries can be bad. All it take is one dead cell in it and it won't be enough to start the mower. The other thing to look at is the cranking amps of the battery. The cheapest wally world battery won't cut it for the larger motors. www.nnyparts.com
May 29, 2010 | Garden
17 hp poulan mower 42" deck wont start
Recheck the valve lash sometimes they are set too tight. Do a compression test if the valve are set ok. If it indicated lower than 80 psi it may be a burn out valve.
Jul 20, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
4,105 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
