Question about Casio Exilim EXZ75 Digital Camera
Everytime I turn my camera on it says either "retry power on" or "lense error"
  • talilib May 20, 2009
    Is that really necessary criminalmind...I'M CRYING RIGHT NOW! thanx...dbag.
    Problem Solver:
  • 5 Answers
GO **** YOURSELF AND TURN IT ON IT ACTUALLY WORKS .... DON'T BELIEVE ME GO DO IT .... WHAT ARE YOU WAITING FOR .... GO **** YOURSELF !!!! NOW !!!!
Posted on May 20, 2009
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: my camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Posted on Jul 28, 2009
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
My camera lense is stuck and my camera wont turn on
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My lense wont go back in after i turned my camara off
i dont no that happent to me and i dont no if i can exchange it.
May 16, 2009 | Casio Exilim EX-Z57 Digital Camera
I just got a kodak c913 camera yesterday and everytime i switch it on it stays on for seconds and then switches off, help!
My co-worker brought me a C913 with the same problem. I took out the batteries, took out the SD card, played with the buttons... nothing. A web search was unfruitfull. For fun, when I turned it on, I grabbed and held the lens. The camera turned off but the lense stayed out. I turned on the camera, the lense stayed out and the camera WORKED! I turned it off, the lense docked properly. I turned it back on, it worked... Woohoo! Theory: Either the lense was slow at coming (binding) out or was not coming out far enough. The camera shut itself off because it wasn't fully extended in an alloted period of time. Hope it works for you. Glennster™
Dec 26, 2008 | Kodak EasyShare C913 Digital Camera
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
205 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
