Question about Jenn-Air Kitchen Ranges
Burners not working - Jenn-Air Kitchen Ranges
Kenmore 30" Drop In Model # 911.45565791. Turned on the r. front burner and it sparked at terminal block. Swapped coil with the other one and it still did not work. Did not see any broken wires. Replaced terminal block, any ideas? All other burners, etc. work fine.
Posted on Aug 09, 2014
I bought a new desktop computer and I can't seem to get Windows 10 to recognize the burner. I don't know what will be needed, in order, to get the burner working with Windows 10.
It's probably just a case of finding the right drivers for it. Search for your burner make and model number with the word "drivers" and see if any come up for Windows 10.
Feb 20, 2016 | HP DVD1040e DVD-RAM Burner
Grillmaster burner no gas
Check and see if burner is blocked or injector to the burner is blocked
If you swap 1 of the buners over this will show you what is blocked
Jun 24, 2012 | Sunbeam Grill Series 760
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
Why wont my mitsumi cr-48x9te cd burner not work
Install a the appropriate cd burner driver software in your
laptop so that it will function properly. A CD disc installer normally goes with the unit you purchase. You
may ask assistance from the store where you buy your
CD burner. Or you can download it from the internet.
Just send in your comments through the e-mail.
Oct 04, 2009 | Mitsumi (CR-4804TE) CD-RW Burner
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections.
With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
Jun 17, 2017 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
73 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
