Question about Precor EFX 546i Elliptical Version 4
Is there a replaceable fuse for the efx 546i - Precor EFX 546i Elliptical Version 4
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Battery operated 546s have a fuse on the lower board, plug in models have a fuse on the lower board and fuses in the power inlet.
Posted on Jan 10, 2015
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: I have an efx 546i and when I try to use the
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
What kind of battery do i need for efx 546?
There a few possible options for the battery. This link will take you to all of them. Please have your serial number ready to help narrow your choices.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Jun 21, 2014 | Precor EFX 546i Elliptical Version 4
How do you replace battery for precor efx 546i
Depends on the version - some have the battery in the front, some have it in the back. The one in the picture next to your question would have it in the front, on the bottom. Take the old battery to Batteries Plus or similar retailer to match it up.
May 02, 2014 | Precor EFX 546i Elliptical Version 4
EFX 546i eliptical battery location
The battery is usually located at the back of the machine towards the top -- there may be a circuit board on top of the battery. And the second link listed below is a technical bulletin for certain models to help prevent damage to the battery during installation.
This link will take you to the 546i models and parts list. You can also find a parts diagram but you will need to match your serial numbers to the ones listed so you can pull up the correct diagram:
http://www.sportsmith.net/images/Pick_Docs%5Cp0645969101-BatteryInstallationWarning.pdf
Feb 03, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
Where do the batteries go on the efx 546i
Dec 31, 2013 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
Precor efx 5.33 belt replacement
This link will take you to the replacement belt. If you use your serial number, you will be able to access a service manual on our Website to assist with the belt change. Drive Belt Poly EFX PPP000000010217131 SPORTSMITH net
Jul 01, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
214 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
