Question about Sony FWD-50PX1 50 in. HD-Ready Plasma Television
Rgb inputs dont work
The RGB inputs dont work but the composit does what would cause them to go out
  • 3 Answers
The connection board or your digital board is bad change the connection board first it is cheaper, then if that does not solve the problem change the digital control board, this is the board where your control panel and connection board is connected to....
Posted on Nov 04, 2008
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
My question is where is the cable connection on the ALT3213om model
Not all models have cable inputs, if you don't readily see a cable input, you will have to use the RGB inputs or composite input. You may have to acquire a converter to convert cable to RGB or Component input.
May 15, 2015 | Televison & Video
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
I just got apple tv and don't know if I can hook it up to my gm-v42ug flatscreen tv Apple TV takes HDMI but the tv doesn't have an hdmi input that I can see. Can I hook it up? If so, how/ Thank you!
the tv has as follows. Use the bnc conectors to hook it to the RGB & R and L Audio. or reg Comp input ( Yellow ,Red White.) can get adaptors at the Shack. Inputs
Composite BNC Back Composite RCA Back Component 3 BNCs Back RGB 5 BNCs Back RGB 15-Pin Dsub Back RS232 DB-9 Dsub Back
Dec 25, 2010 | JVC GM-V42UG 42 in. Plasma EDTV
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not seem to work
Well, lets start here first. I would like you to look at the input jacks for a/v3 and a/v4 and see if they are color coded RED-GREEN-BLUE. or if they are just YELLOW-RED&WHITE (audio). If they are RGB then just buy RGB cables at your local Best Buy. If any are just Yellow and Red & White then those are just regular composite video the same as the old vcr's. You can't make A/V jacks work like RGB component jacks.
Dec 01, 2010 | Televison & Video
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
No video from rgb inputs
usually this is a bad connection on the system board, cable, etc.  If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit.  Worst case scenario is replacing the system board where the connections reside.
Oct 19, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
