Question about Refrigerators
Handle broken, need to replaces... Tried of dirty little hands in my ice..
How do I get the door off or open to install new ice maker handle.
  • 700 Answers
Your going to have to take the ice maker handle and disconnect it from the back of the maker then move it around and at the same time pull it towards the back until it comes out.
Posted on May 21, 2009
I have a Model HZB-15/BF ice maker the handle on the ice bin is up and I cannot remove the bin. What do I do?
maybe its frozen.leave the door open for a little bit, or use a hair dryer to warm it, Matt gently push in on the drawer or tap on it
Jun 26, 2015 | Chard International LLC Chard Stainless...
Outer door handle does not open door on drivers side how do I fix it? Inner door handle works.
There are one of 2 things wrong here. Either the outside handle is broken, and you'll need another one, or it is out of adjustment and can be repaired. It's a little work to find out either way, the inside door panel must be removed. This is lots of screws, you'll see as you start removing them. The black triangle plastic near the rear view must be taken off, pry the little round plug out and then remove the nut. Finally the panel lifts up, give the bottom a smack upward with your hand, it WILL come up.
Now is the tricky part, you need to see whats wrong. There is a rod connecting the door handle to the door release. If the rod looks like it moves up and down when you move the outside door handle up and down then it needs adjusting.
See the picture of the door handle...the white nylon clip on the right must be separated from where it attaches to the rod, then the rod is positioned higher so the handle can pull it up enough to open the door.
If the rod does NOT move when you move the handle, either the rod is completely loose, or the handle is broken. Remove 2 nuts from the inside and the handle comes out, and put back in a junk yard or ebay replacement. Good luck...Chris
Sep 18, 2011 | 1991 Mercury Capri
How do I get to the screws on my Whirlpool ED5GVEXVDOO I need to tighten the door handles
Your model does not have screws to the handles you can see. With the door closed, use two hands and grip the handle, with a little force pull up on the door handle to release it, the screws you seek are behind the handle on the door itself. Reverse directions to install handles.
Good Luck
Aug 14, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do you replce broken door handle?
This is a problem that you should be able to fix. With the interior door panel there are 3 screws. 2 in the arm rest and 1 on the door handle(opener), take those out. There is a C-clip on the window crank that needs to be removed. They make a cheap little tool to remove those but I've heard people using a shop rag and removing the c clip. To remove it, turn crank to around 9 oclock then slide the tool or rag behind the crank also coming from 9 oclock. Any position will work, my point being the tool must slide in from behind the crank handle. Use a flat head screwdriver to gently pry the edges of the door panel away. There are some little clips that pop loose. It's okay if some break you can buy more. After that you will slide the door handle (opener) forward a little to pop out. Twist and turn the panel to get it over the door handle. There are 2 bolts that hold the handle on from the inside. They are 10 mm. You can reach the most forward one pretty easy but the back one is taken out through a hole in the metal door panel. Mine had a sticker over the hole with a big yellow dot on it. After that it takes some pretty good force to get the handle out of the hole. Don't be afraid to push on it. When it pops out take some wire cutters and cut the little plastic clip that holds the metal rod to the handle. The lock twists out of the hole. Now this is when you need 3 hands. Hold the new handle close to the opening and twist the lock into position. Don't attach the metal rod yet. Now actually put your key in the lock. This helps you hold the lock in the correct position while inserting the handle. Put the top of the handle in first and then the bottom should snap in next. Now from the inside, reach up and slide metal rod in the hole and rotate the plastic clip to secure it. Now the hardest thing is getting that back bolt in. It helps again to leave the key in the lock and rotate it so the bolt can secure the locking mechanism to the handle. Put the front bolt in reinstall the interior door panel and you should be in business. Good Luck
Feb 03, 2009 | 1995 Geo Prizm
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
