Question about Sony FWD-50PX1 50 in. HD-Ready Plasma Television
No video from rgb inputs
What would cause the RGB  to not show video but the only video that works is the composite video input
  • 70 Answers
Usually this is a bad connection on the system board, cable, etc.  If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit.  Worst case scenario is replacing the system board where the connections reside.
Posted on Oct 19, 2007
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not seem to work
Well, lets start here first. I would like you to look at the input jacks for a/v3 and a/v4 and see if they are color coded RED-GREEN-BLUE. or if they are just YELLOW-RED&WHITE (audio). If they are RGB then just buy RGB cables at your local Best Buy. If any are just Yellow and Red & White then those are just regular composite video the same as the old vcr's. You can't make A/V jacks work like RGB component jacks.
Dec 01, 2010 | Televison & Video
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Rgb inputs dont work
the connection board or your digital board is bad change the connection board first it is cheaper, then if that does not solve the problem change the digital control board, this is the board where your control panel and connection board is connected to....
Oct 19, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
