Polaroid tv problems
Polaroid 40" P40Led13 tv my plug in dvd keeps changing back to the tv again
  • 74 Answers
SOURCE: RC 201 POLAROID TO WORH DISHNET
Try calling the Dish network customer support phone number. Only they can tell you the code for the remote you have, that matches the box you have.
If you have the manual for the poloroid it should tell you if the Polaroid is a universal remote and show codes in the manual. If no codes in the Polaroid manual then it is not a universal, so it can not be done.
Posted on Mar 25, 2008
jyackle5
  • 8197 Answers
SOURCE: need code for tv ( polaroid 40" LCD)
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off (after pressing POWER). If the device does not have a
Power key, you can substitute another function, such as
digits 0 ~ 9 , CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will blink
twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
good Luck And Please RAte FixYa!
P.S. it might take an hour to set.
Posted on Dec 29, 2008
SOURCE: polaroid tv codes
Hi, try this site out, pick the comcast universal remote that matches the one you have (from the pictures provided) and type in the type of tv, yours being a Polaroid, then your model information ( FXX 321C) , there are instructions provided on the site when you get to that point, good luck
http://www.urcsupport.com/index.php?mso_id=65
Posted on Jan 30, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
Takeit Apart
SOURCE: DVD Player that repeatedly says NO DISC for Polaroid PDM-0752
hey buddy I have the fix for the Polaroid DVD player PDM-0743 you have the PDM-0742 it looks alot like mine see if this link will help you out any
http://www.fixya.com/support/t1892378-shows_bad_dics_all_time
Posted on Jun 03, 2009
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
40 inch polaroid lcd tv
This is a common problem with Polaroid sets. I would check the power supply/inverter board for any capacitors with bulging tops. The typical ones that cause this problem are 10uf 450V caps.
May 07, 2013 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
I have a Polaroid 19 inch TV/DVD Combo. I put a DVD in the other day and now it's stuck. It keeps showing a blue screen and says ''NO SIGNAL''. Everything is plugged in . I have unplugged and plugged and...
Go to YouTube.. search how to get a stuck DVD out...
I would do this first then see if everything is working again..Also some DVD's that are boot leg don't work to good...not saying you have one but the paper label sometimes is thicker and they get stuck
Nov 11, 2017 | Polaroid Televison & Video
Can't program the channels
Here is where I found the remote code (1256) for the TBX-2000AF and it has many more codes for Polaroid models. Good luck (copy and paste this link) http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/popup_adp.php?p_sid=fPLB5Gzi&p_lva=&p_li=&p_faqid=2854&p_created=1116267791&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xOTk0JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**
Apr 15, 2007 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Electro Med Services...
