Brand new machine. Coffee is only warm and if any is left in the carafe it's cold within 10 minutes.
SOURCE: mr coffee model isx43 12 cup
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
SOURCE: New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
SOURCE: Coffee spilling out the sides of the carafe
Clean it. Running vinegar thru it might work but for best results, remove the base and then remove the return hose (rubber tubing going to up spout). What's happening is it's clogged liked an artery so some water is spitting back into reservoir. When it gets to near the bottom it shoots pretty high, hits the cover and splashes outward.
SOURCE: Just purchased a PSTX series coffee maker. It is
No in the BVMC-PSTX90 or 95 series.
If this is your model, Is a good coffee maker.
If you are NOT drinking your fresh brewed coffee withing 25 min. YOU DON'T WANT a warmer/burner.
And the reason why, IT BURNS the coffee. You don't have this problem with the "thermal Carafe".
Testimonial: "Thanks! It is a great coffee maker and the coffee does stay warm!"
