My 1986 ford econline 350 a/c compressor is not working. the clutch will not ingage. I have a good ground but i can't find a power wire for it where would it be located. I checked the a/c fuse and i have power ?
  • Dennis Boxerman May 11, 2010
    Look for the accumulator. It is a large, round, cylinder type device with freon lines going to it. Usually aluminum. It should also have a switch screwed into it with 2 wires. Start the engine, put the a/c on High and Max. Disconnect the switch by unplugging the wires. Take a small piece of wire and use it to make a connection on the unplugged wires. If the compressor starts to work, you either have a low freon level or the switch is bad.
    check this out and let me know.
  • kuz1 May 11, 2010
    Find the high pressure, two pin switch, probably on the side of the drier. Pull the plug, and ground out the pigtail while the AC is turned on, engine running. The compressor clutch should start. Does it?
  • 20 Answers
Sometimes it's not electrical it might be low on charge causing the low pressure switch to open and not allow the compressor to get power and engage the clutch
Posted on May 24, 2009
Replaced the ac compressor but now no power to compressor but have power to low and high pressure switches. checked relay under hood, relay and fuse in cabin. what am i missing?
Put a jump wire in the high pressure switch plug. If the compressor works. replace the high pressure switch. Let me know and we can go from there.
Aug 22, 2011 | 1999 Ford Expedition
95' ford econline 350 van replacing waterpump and clutch fan how to replace.
TO REPLACE WATER PUMP.REMOVE THE RADIATOR SHROUD HALVES.REMOVE FAN CLUTCH AND FAN.YOU NEED FAN CLUTCH WRENCH AND A FAN CLUTCH PULLEY HOLDER.YOU CAN RENT TOOLS AT AUTO ZONE OR BUY THEM AT A AUTO PARTS STORE.THE FAN CLUTCH BOLTS ARE LEFT HAND THREAD. REMOVE THEM BY TURNING CLOCKWISE.BEFORE INSTALLING NEW WATER PUMP COAT BOTH SIDES OF WATER PUMP GASKET WITH GASKET SEALER.TORQUE WATER PUMP BOLTS 18 FT LBS.
Mar 15, 2011 | 1995 Ford Econoline
1986 chevy S10 has no power (12v) at fuse box on the fuse for ac clutch. checked both sides of fuse to ground 00v. ac/heater fuse 12v both sides (fan) works fine
hello, check all fuses, and relays, make sure wires to ac is not broke or has been pinched, sometimes you can run hot wire from battery, to compressor, touch hot side of plug in on comp wire see if it will kick on, if so sounds like a short, if compressor dont kick on with hot wire run to it, tap the out side of comp clutch and see if it kicks on, these compressors will not kick on any way if they are low on freon, once freon is full it should work.
Apr 08, 2010 | 1986 Chevrolet S-10 Blazer
Ac compressor will not ingage it has refrigerant in it and low pressure switch is working any ideas
check the ac fuse for continuity and then check the relay that supplies power to the compressor,and then unplug the "magnetic clutch coil" that in front of the compressor and check that coil for continuity.they draw a lot of current and can burn open after time ,and also clean any connections as well, especially ground connections
Apr 06, 2010 | 1991 Ford Aerostar Extended
I have a 1986 Ford F-350, 6.9 liter pickup. The injection pump doesn't push fuel to the injectors.... I have tried another pump but that still doesn't work. Any suggestions on the problem?
Yep!.. the problem is electrical wiring (that's only if you've VERIFIED the replacement pump is GOOD!). If you don't have POWER and GROUND at the fuel pump connector, doesn't matter if the pump is good or not... if the pump isn't receiving power (and there's a questionable ground), the pump will not operate correctly.
Sep 10, 2009 | 1986 Ford F 350
Air conditioning not working
put 12v straight to the compressor if the clutch ingages comp is good turn ac on is it stops then you are low on freon jump the short cycle switch & charge the system
Jun 05, 2009 | 1988 Ford F 150
1986 bronco back window will not go down
the electric motor is grounded and powered by the two wires. the down command applies power to one wire and also applies ground to the other wire at the same time. an up command just reverses the power and ground in the wires. unplug the motor and applie power and ground from another battery or jump pack to see if the motor works.
good luck chris
Apr 01, 2009 | 1986 Ford Bronco
When replaced the fuel send unit the fuel gage sits on empty
Try grounding the gauge wire at the tank. If the gauge and wiring are good the gauge will go way past full when you do this.
Mar 01, 2009 | 1986 Ford F 350
1979 ford f350 clutch pedal travel 1/2 inch
sounds like the clutch armerature may be hanging or broke. it's the rod that ingages the clutch.
Nov 09, 2008 | 1979 Ford F 350
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
