Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Stopped, cycle incomplete and no lights are on. What can I do?
Kitchen Aid dishwasher won't start. All keypad buttons/lights appear to be functional.
The touch pads are common to go bad. It could be a bad start switch pad or bad control board.
Oct 05, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Spin cycle incomplete
sounds like you may of had an unbalanced load. It will not spin if it can not balance the load.
Dec 27, 2013 | GE Washing Machines
GE WASHER LIGHTS FLASHING BUT NOT WORKING
It won't change because the cycle was incomplete and the safety control is preventing a restart. Until you get professional onsite service; unplug the washer; make certain all of the water is drained out, and disconnect the hoses. Have someone help you tilt the washer forward and lay on the front side. Pick it up again and reach into the tub area and spin the tube around, and kind-of move it side to side. Hook it back up, plug it into the power supply and reset the timer to start a short wash. Try to start and see if you get any action. If after all of that; nothing changed, the timer on the circuit board is stuck where you left off when the unbalanced load shut it down.
Dec 23, 2013 | GE Profile WPRE6100G Top Load Washer
Incomplete dishwasher cycle
You need to double - check if the dishwasher door is properly closed.
Sep 11, 2012 | Hotpoint Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
I am working on a 2004 Ford Explorer 4.0l have replaced O2 sensors and was attempting to get the vehicle ready for state inspection preformed the drive cycle and after drive cycle completed I am still...
Some times it takes several days to reset the drive-cycle = Starting from cold state, different speeds for a certian distance, EVAP from cold condition and time. If the PCM dosen't get the proper readings from the sensors it won't reset untill it does. If you keep getting an " incomplete" on a system, then there's a problem with that system and you will have to find and repair it.
Give it a few days of running varried trips.
Mar 16, 2011 | Ford Explorer Cars & Trucks
My model number is FDB1500LFSO, my dishwasher quit...
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
Condensor fan runs during harvest cycle , hot gas valve energizes, evaporator harvests ice incomplete
Sounds like possibly a bad relay in the controls.The condenser fan is supposed to turn off during harvest. If the harvest is incomplete, and I do not know if your model has an ice curtain or not, I will assume it does and the curtain switch is not operating properly. No model, can't be more specific.
Jan 10, 2010 | Manitowoc Refrigerators
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
19 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
