Question about Apple iPhone Cell Phones
How to delete playlist - iPhone Apple Cell Phones
How can I delete songs from my iPod playlist?
If you want to manage songs on your iPod's playlist, then you can count on this iTransfer tool. It helps you manage playlists of the iOS devices/iTunes. You could add music to playlists, export/rename/delete the playlists.
Leawo iTransfer User Guide How to Manage Playlists of iPhone iTunes
Jan 12, 2017 | Apple iPod Audio Players & Recorders
How do I delete a playlist from an iPad?
If it is a playlist that you created on the iPad - not a synced playlist - just tap and hold down on the playlist icon and an X will pop up to delete it.
Jul 13, 2014 | Tablets & eReaders
Do not privacy on my playlists. How do I get it deleted?
you can delete your playlist by going to your playlist delete option where you can delete your playlist as you want.
Mar 24, 2013 | Audio Players & Recorders
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
Apr 29, 2011 | Audio Players & Recorders
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip won't hold playlists
If you instal rapsody you can create playlists through their software.
Oct 03, 2009 | SanDisk Sansa Clip MP3 Player
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Jan 15, 2009 | Alesis MasterLink ML-9600
How do I erase the playlists on my sansa fuse 2gb player?
connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
Sep 26, 2008 | SanDisk Sansa e200 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
Sep 24, 2008 | Philips Audio Players & Recorders
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
Apr 13, 2008 | Audio Players & Recorders
Cell Phones Logo
335 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
