Question about Electronic Arts Sims3 Sims 3 - Pc -pcsela15390- pcsela15390
Sims 3 activation code - Electronic Arts Sims3 Sims 3 - Pc -pcsela15390- pcsela15390
How to get a activation code.
you can just google sims 3 starter pack serial and you will find the code
May 13, 2015 | Electronic Arts The Sims 3 Starter Pack
I lost my regestration code for sims 3 I need a new one so I can activate my sims 3 starter pack thank you
Contact support and request a new activation code, you can not use the older one, because is already used, ask to resend a new activation code. Hope this help.
Jan 23, 2015 | Sims Video Game Consoles & Games
Yar sim card rejected
There may be various reasons for it.
1) Your SIM card might be damaged. Check inserting the SIM card in any other active unlocked phone.
2) The SIM port on the cell phone might be damaged. Check inserting any other active SIM card to your phone.
3) The cell phone might be network restricted. Try inserting any other network's active SIM card to it. If the device reject that too, then you need to unlock the phone. You can unlock a Nokia C1-01 safer and easier using unlock code. You can get the accurate unlock code for a Nokia C1-01 from TheUnlockArena.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia C1-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C1-01.
3 - Compose #pw+CODE+1#.
4 - The Nokia C1-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C1-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C1-01
Oct 05, 2014 | Nokia C101
Forgot phone lock code for GT-S5233S
Unlock Code
#*7337#
Entering Code instructions
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
Alternative Solution if the above fails
Unlock Codes
Code 1: *7465625*28782#
Code 2: *7465625*28638#
1. Remove SIM Card from handset
2. Enter Code 1 into the handset
(Your handset will display "auto subset lock activated")
3. Enter Code 2 into the handset
a) Enter an alternative network SIM card into your Samsung and reboot.
cool.gif The new network should be displayed in handset window.
c) If the process is repeated with yet another alternative network SIM card,
you may be requested to input a security or pin code to enable the use of
the new SIM card.
d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted.
e) Finally once again enter 00000000 (8 zeros) and this should permanently
unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung Star GT-S5233 Cell Phone
Registration code for sims 3
I'm sorry but this is not a warez site...We can't give out activation keys or access codes...
Sep 08, 2012 | Electronic Arts The Sims 3
Registration code for sims 3 pc
Aug 13, 2012 | Electronic Arts The Sims 3: Pets Expansion...
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 | Nokia 1100
Daughter seems to have blocked her sim card as it is saying sim card rejected
This is a most common problem.in this situation there is no way to active your sim card without requesting a duplicate sim card from your service provider. how to get rejected?-when you enter the phone pin code incorrectly in 3 times.it will ask PUK code If you type the code incorrectly 8 times the sim card will be rejected.this is happened to you.
Oct 26, 2010 | Cell Phones
Have sims 3 but misplaced booklet for activation code
It sounds like you are installing Sims 3 onto a new computer. Is this correct? If so, and you have the old computer still, fire it up, connect it to the Internet, go to http://belarc.com/ ---> hover over the "FREE DOWNLOAD" tab, the drop down menu will appear ----> click "Download" on the drop down menu ----> click Download Belarc Advisor ---> Click "Run" when prompted ----> Agree to the License Agreement ----> Click "Install."
In a few moments the Belarc Advisor report will generate. In this report, among other things will be a list of the installed programs AND their activation keys.
If the scenario of the old computer doesn't apply to you, if you've previously registered the software, you may be able to contact publisher and get your activation key.
Nov 28, 2009 | EA - Electronic Arts Sims: Complete...
Electronic Arts Sims3 Sims 3 - Pc -pcsela15390- pcsela15390 Logo
61 people viewed this question
Top Electronic Arts Computers & Internet Experts
Tom Chichester
Tony
Martin Murray
Are you an Electronic Arts Computer and Internet Expert? Answer questions, earn points and help others
