Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Dishwasher spots How do you get the spots off of glasses from the dishwasher
  • 130 Answers
I'm sure you use rinse aid? If not try it. Also cut down on the amount of soap you use. If these dont work your water may be to hard, and you'd need a softner.
Posted on May 20, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: Glasses have a film when dishwasher is done.
There are several things that could cause this; 1. The rinse agent dispenser is out of rinse agent(Jet Dry). 2. The dispenser is not working and is easy to replace by removing the four screws that hold the door panel on and the two that removes the dispenser(be sure the breaker is turned-off). 3. The water temperature coming into the unit from the water-heater is not hot enough. 4.Your water may need to be tested for excessive minerals or chemicals. 5. Low grade detergent may not dissolve correctly.
Posted on Aug 06, 2010
Glasses look awful after being washed, maybe I need maintanance
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. After that it is recommended to use a little vinegar in each cycle to maintain the clarity of the glass.
Feb 25, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
I have a new Ge profile modesl pdw7880 dishwasher. It does not clean the dishes. The glasses have a milky white film and spots. The black arm on the bottom has a white coated build up. Also there is a...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 14, 2011 | GE 24 in. Profile PDW7800 Built-in...
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
White film on dishes and glasses
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 12, 2010 | Asko 1385 Dishwasher
Right after 1 year, now there is a white film on all the glasses and bad spots, that rubs off if you wipe it fresh out of the dishwasher. Yes, we are using rinse aid.
Dec 04, 2010 | Whirlpool 24" Black BuiltIn Dishwasher...
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
What causes a film to be left on glasses after being washed in dishwasher?
Aug 07, 2010 | Kenmore 15899 Built-in Dishwasher
White spots left on glasses and silverware
The white residue could be water spots from hard water. They are most notably left on clear plastic glasses, clear glasses, and silverware. If your silverware is authentic sterling silver you shouldn't be washing it in the dishwasher anyways as this ruins it.------
The best advice for the hard water is to use jet dry there should be a dispenser for this on your dishwasher. The other solution is to use those oxi clean tablets or the cascade 2 in 1 gel packs. normally,this is caused by hard water. try using a dying agent like jet dry, it will stop the white spots. good luck.--------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | Hoover 24 in. DT999 Free-Standing...
We have jp-24B series dishwasher it was doing great until about 2 months ago and the glasses come out all spotty. The dishwasher seems to be running through all the cycles and it gets up to temperature but...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Feb 23, 2009 | Jackson JP-24B Built-in Dishwasher
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
108 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
