Question about Homedics Rc Quad Quad Extreme Rechargeable Hand Held Massager with Charging Base and Adaptor, Black and Chrome
What is the voltage for charger
Ac adapter
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
When connected to AC mains and switched on there was no sign of glowing led displaying charger is "ON"
Use multimeter to check output of AC Adapter. If no DC output at required voltage you should replace adapter; available after market units sell for $10 to $15 delivered.
Jan 03, 2014 | Compaq 239427-001 Laptop AC Adapter...
I plug charger in and hav no led light to say charging battery nearly dead
If you have a Volt-ohm meter you can check if the AC adapter for your laptop is giving out the correct voltage. Also if you have a meter and you can see that the voltage is correct on the adapter try taking out the battery and plugging in the ac adapter and test the battery connection on the computer for voltage, if do have voltage to the adapter but not the battery terminal it could be a motherboard issue. A quick question, is the ac jack loose or does the plug move around easily when plugged in?
Mar 16, 2012 | Dell Studio 17 Laptop
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
Keeps loosing battery/power
If it will not work on AC Adapter without battery in it, then you have a bad AC Adapter and the battery is fine. You don't have to get an expensive AC adapter from the original manufacturer. Just look on the bottom of the AC adapter and write down the Volts and Wattage. You can get another at a place like Lowe's or Home Depot. But you must make sure that the Voltage matches exactly, to much voltage and it will fry your computer, to little voltage and it will not run your computer.
Dec 23, 2008 | Toshiba Satellite 2455-S305 Notebook
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Overseas Use
The operating voltage of the AC Adapter Kit/Compact Power Adapter/Battery Charger is 100V - 240V and conforms with international standards. Voltage may be unstable in some countries/regions. Please take care when using the device. The shape of the plug varies depending on the country/region. Make sure the conversion plug adapter is the right shape for your location.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Overseas Use
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Power Adapter
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Homedics Rc Quad Quad Extreme Rechargeable Hand Held Massager with Charging Base and Adaptor, Black and Chrome Logo
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
