Question about Troy-Bilt Garden
Troy bilt tb525es leaks oil
Air filter
2 Suggested Answers
  • 81 Answers
SOURCE: How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Posted on Jun 24, 2009
BP Blower wont idle with filter on
Because it's a troy bilt... Obviously the carb has become plugged
Dec 22, 2013 | Troy-Bilt 32cc 4Cycle Backpack Blower
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
Troy-bilt cultivator 26cc gas/oil separate engine spewing oil out through filter when running...there is a hose from the oil reservoir straight into the back of the filter...as the engine revs it literally...
Hi, Check the oil reservoir breather that it's not plugged up. The oil should be returning back to the reservoir not going to the filter. That tells me that there is air being pumped into the engine (oil).
The piston rings could be broken or the carberator needs to be readjusted.
Open the air screw abit more on carb. Then see what happens. Good luck.
Jul 30, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
I need an owners manual for a tb525es string trimmer
Go to troy bilt web site,here is the link to the manual page:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
If you can't find the serial number, just make up a number and it will still search and locate the manual just by the model number
Jul 19, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt mower 6.75 hp smoking too much oil
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
May 19, 2010 | RTO Lawn Boy 6.75hp Mower
Won't start after 3 seconds it stops
try changing or cleaning the spark plug and scoket
Aug 18, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
32 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
