Question about New Ray Rc 112 Yamaha Srx700 Snowmobile Set2 88003
Flashing diagnostic light on 97 mountain max 600
2004 Mountaineer no start no crank? Battery, starter, fuses, relays all good. No code errors. PATS problem. Original keys&fobs all good even reset manually and good. All dash lights functions ok.
. quick flashing when ? when trying to start the vehicle ? If yes you need to have it checked for codes . Do you know what DTC'S - diagnostic trouble codes are . If that light is flashing while trying to start the vehicle codes are present in the module that controls PATS . Instead of guessing have towed to a qualified repair shop . Because you have no idea how to diagnose this system .
Dec 28, 2016 | 2004 Mercury Mountaineer
Cant remember how to connect ignition coil wires
sounds like your ignition is 180 out
easy to do swap the ht leads over for each pot
Jan 11, 2014 | Yamaha 97-98 Mountain Max Vmax Sx Sxs Xt...
97 vmax won't start
check battery is charged if it is check hidden fuses, i had the same problem with the thunderace, i thought it was the battery but it was a hidden fuse
Jan 27, 2013 | Yamaha 97-98 Mountain Max Vmax Sx Sxs Xt...
No spark on Yamaha Mountain Max 700
plug bad, coil bad , spark plug wire bad, battery dead????
Dec 08, 2012 | Yamaha Mountain Max 700 600 Snowmobile...
Codes on yamaha mountain max 700
Probably nothing wrong with the bike and probably needs the obc memory cleaning
Nov 25, 2012 | Yamaha Mountain Max 700 600 Snowmobile...
The alarm system of my 1997 BMW 740iL is really annoying. I try to turn it off, follow the instruction of my manual, by press the lock key again after I locked the door. However, the red light of the alarm...
Flashing light mean something is been tampered with on car, either locks, ignition, radio etc, Had similar problem, could only be reset with diagnostic computer.
Jul 10, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
New Ray Rc 112 Yamaha Srx700 Snowmobile Set2 88003 Logo
48 people viewed this question
Top New Ray Toys Experts
Josh Van Nostrand
Owen Barnes
Bruce Burgess
Level 1 Expert
Are you a New Ray Toy Expert? Answer questions, earn points and help others
