Question about Cell Phones
Fix ya com
How can i program a keyless remote for a 2012 hyundai sonata
Can you by pass out of toner cartridge on cannon all in one f189402
Posted on Jan 21, 2014
HOW PROGRAM THE KEY LESS ENTRY FOR SONATA 2012
  1. Cars
  2. Car Maintenance
  3. General Car Maintenance
  4. How to Program Keyless Entry Remotes in a Hyundai Sonata
How to Program Keyless Entry Remotes in a Hyundai Sonata By Christian Killian, eHow Contributor
20Found This Helpful The keyless entry system in your Hyundai Sonata is part of the factory alarm system. If you have to replace a lost or damaged remote, reprogramming will be necessary. The remote is important because not only does it lock and unlock the doors, it also arms and disarms that factory alarm when you open or close your car doors. New remotes are available from any Hyundai dealer. While they will program it for you, you can do it yourself and save a programming fee.
How to Program Keyless Entry Remotes in a Hyundai Sonata(Kleophaus Livingston/Demand Media)
Other People Are Reading
Step 1: Locate the fuse panel under the dash on the driver's side of the car. Just below it is the control module for the factory alarm system. Open the cover on the alarm system control module and locate the memory switch inside.
(Kleophaus Livingston/Demand Media) Step 2: Verify that the switch is in the "Off" position; if it is not, switch it to the "Off" position. This is important for the system to understand what you want it to do when you move to the programming mode.
(Kleophaus Livingston/Demand Media) Sponsored Links
Step 3: Insert the key into the ignition of your Sonata and turn the key to the "On" position. Wait for 60 seconds, then move the memory switch inside the control module to "Set."
(Kleophaus Livingston/Demand Media) Step 4: Depress and hold the "Lock" button on your remote for one full minute. This allows the remote and the control module to communicate and sync. Release the "Lock" button and turn the memory switch in the control module back to the "Off" position.
(Kleophaus Livingston/Demand Media) Step 5: Turn the ignition switch to the "Off" position and test the remote by pressing the "Lock" or "Unlock" button, verifying that the doors do lock or unlock.
Read more : http://www.ehow.com/how_6362326_program-entry-remotes-hyundai-sonata.html
Mar 29, 2015 | Hyundai Sonata Cars & Trucks
Lost my keyless entry remote and key to 2010 hyundai eleantra
Your solution is to contact the nearest Hyundai Dealership to acquire new remote(s) and have their Service Department program the new remote(s) to your vehicle.
Sep 06, 2011 | 2012 Hyundai Elantra
How do you program a Hyundai Sonata keyless remote
Hyundai uses a system called the GDS (Global Diagnostic System). It is a proprietary system and the only way to 'PROGRAM' any remote is to take the vehicle to a dealership and pay to have it done. SORRY!
Oct 02, 2009 | 2008 Hyundai Sonata
Sonata 06 keless programing
I have heard of a site that would help you regarding programming your remote :-
http://keylessride.com/
Hope that i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | 2006 Hyundai Sonata
Got an used Hyundai Sonata 2002, need to program the remote for keyless entry. Please help.
hi you can look up what we call the chicken dance on the internet for hyundi it is sequence of moves to program new keys and remotes if you cant find hyundi will program for you.
hope this helps
Jun 17, 2009 | Hyundai Motor 2002 Sonata
My 2002 sonata alarm wont shut off and my keyless wont stop it and the car also wont start with the key either
When the alarm is activated, there is an Anti-Theft device (Starter Kill Relay) which prevents anyone from starting the engine using the key (about 5 minutes). If you place the key in the ignition and turn the key to the "RUN" position, wait 5 minutes (approx), the engine should then be able to start. If not, the problem may be the ETACS (Electronic Time & Alarm Control System) module. If it does start, the problem may simply be that the battery in the keyless remote is weak/dead, or the remote needs to be programmed again for that vehicle. Only the remote can 'DEACTIVATE' the alarm. Best solution, take/tow the vehicle into a Hyundai Service Center (dealership), pay the diagnostic fee. They will tell you EXACTLY what the problem is and what's needed to fix it (parts, labor, tax, time-frame, etc.).
Jun 14, 2009 | Hyundai Motor 2002 Sonata
Hyundai sonata 2002 remote
There is a special (proprietary) programming electronics 'black box' for the keyless entry system on all Hyundai vehicles for programming the remotes. This programming is stored in either the BCM (body control module) or the ETACS module (Electronic Time and Control System).
May 22, 2009 | Hyundai Motor 2002 Sonata
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
