Question about Jenn-Air Kitchen Ranges
Fuse location stove - Jenn-Air Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
I have no power to oven or burners. Where are the fuses located
there would be no fuses in the stove itself. Try the house breaker or fuses to the stove.
Sep 20, 2014 | Whirlpool Accubake RF362LXTT Electric...
Where can i find my kelvinator stove fuses
Fuses located on the top under panel. Pull the front ends and bring it up. Oven fuse (two of them) separate from burner fuse
Jun 09, 2014 | Refrigerators
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Fuse location on ge stove
If there is a fuse it should be located on the back of the unit behind a cover plate.Make sure to unplug stove before working on it.Hope this helps.
Dec 30, 2013 | Ovens
Broke Frigidaire Stove
Looks like you have a blown thermal fuse. If you have electrical knowledge you can open up the back, locate the thermal fuse and test it with a continuity tester.
Apr 23, 2013 | Camping, Backpacking & Hiking
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Would anybody know where the fuses are on old stoves? I have an old stove, which I am renting with my apartment. There is no brand name on it but since it is olive-green, it must go back to the 70s, if...
Hello Lucie,
If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. I would highly recommend that you remove or disable power to the stove prior to making any component changes...
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
I would think that your landlord ( since you are renting) would be responsible for the maintence and/or replacement of your stove,,,
Good Luck..
Regards,
Rick
Dec 04, 2008 | Stoves Kitchen Ranges
I have a GE electric profile stove. The range is working the stove is not. What should I look for.
the electric profile stoves have a set of electronic relays in the top of the stove where the digital settings are. the most likely problem is the control module that allows the electrical power to pass through it --is bad or damaged. also there may be a fuse link that blew out. The ovens and stove tops are usually on seperate relays. If the relays are solid state (soldered) you will need a technician to replace the relay. If it is just screwed to a panal board you could replace it yourself. Do you have the papers that came with the stove?? if so there should be information on the parts and ordering. also, there should be a schematic diagram of parts location on the stove. This will show you where the relays are located and which is the oven and stove top. or you could go online to www.ge.com and locate the parts and diagrams for replacement.
Oct 13, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
61 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
